Fred's 2016 Painting Diary
Started by fred., 01 January 2016, 03:26:56 PM
It was a good game - hence the lack of photos from in the middle!!
Hello
Another great looking game. You really know how to torture a game-rule-aholic  :D. It's always a good sign that there's a sparsity of pictures from the middle of a game, it means you were having too much fun to think about taking pictures. Too many pictures means that the game's dragging and you have to fill in the spare time  :D
I like how there's not too many intrusions on the table, apart from command dice, as well.
Looks very nice Fred.
Any game with elves in is good  8)
If they win - even better  ;)
Quote from: GrumpyOldMan on 18 May 2016, 12:39:40 AM
We keep it simple, dice and tape measures. And the occasional army list. One advantage of having written the rules is that most of it is in my head so we rarely need to actually look something up.
Pike and Shotte
Got these chaps based up tonight.
The Shotte are EL3 Arquebusier in cabaret. The pike are a mix of EL and ECW codes (and probably some others). The wizard stand are various GW Warmaster Empire figures.
I remembered to mix some brown paint with the PVA on the back two stands which should help with painting the basing sand a lot.
Hello
Quote from: fred. on 18 May 2016, 09:58:49 PM
Pike and Shotte
It must have been hard to paint the Fishnet stockings....  ;D ;D
Sorry, couldn't resist. Interesting to see somebody else being pummelled by the spell check for a change.
Seriously, they look very good, are these (and the swordsmen) for your home grown rules as well? I'm assuming they are, going by the 40x40 bases.
zackzeta
Quote from: fred. on 01 January 2016, 07:13:00 PM
I'll try to supply a steady stream...
I think I will try to take some more photos of finished units against proper backgrounds - rather than the quick snaps on the painting table.
But quick snaps are easy!
So here are some latests additions to the banana Space Marines, some scouts and some Land Speeders
Who will get their first outing on the table tonight.
wow those are some amazing minis what line is that from?
Thanks chaps.
Quote from: zackzeta on 19 May 2016, 01:31:03 AM
They are old GW Epic Space Marines, 6mm sized. Long out of production but still quite readily available on eBay.
Quote from: GrumpyOldMan on 19 May 2016, 12:10:16 AM
Bloody auto correct - even copied it from the webstore to get the right spelling.
These are probably more likely for Irregular Wars (apart from the wizard). But they may well get roped into a Fantasty army at some point.
Not much painting tonight.
Gave the Renaissance troops a brown wash - including the more sandy bases.
Also tried to paint the canopy lines of the Squat helicopters - with not the best results - so might need to touch them up. Not totally sure what to do with the rotor blades. Had initially thought to leave them black - but not sure if that looks a bit dull.
Hello
Quote from: fred. on 19 May 2016, 09:42:38 PM
Can't help you with the canopy lines. A job I hate and put off, for as long as possible. You could try to liven up the rotor blades with  some dayglo danger markers similar to the tail rotor below. It could be a warning for squats not to become minced  :)
Nice work, again, Forbes !  8)
Thanks chaps.
GoM good idea about the markings - there are some bulges on the rotors (probably not really visible in the photos)
Been putting together a base marker for the Tyranids - its a 40k plastic part, and I have done a green goo base to go inside, using water effects to give both a sheen and a ripple effect
Looks suitably creepy and organic. Look forward to the finished article.
Thanks. Not totally decided on the scheme, I'm using red for organic bits and bone for armour on my Nids, but this piece looks to be s bit different in structure to the beasties.
