Chain of Command
Started by TinyTerrain, 08 May 2013, 09:42:23 PM
Ronan, nice report and good pictures.
It looks like you had a good game even with fairly small forces.
I wouldn't post pics of our games at the moment since they consist of Wehrmacht Space Marines taking on Soviet Eldar  :-[  We are however having a lot of fun with them despite the lack of historically accurate figures!
Cool - glad to see someone else using 10mm.
We have played two games so far, with 10mm - we used inches, because we are lazy! 2cm to the inch, is 24cm to 40 yards, 24cm to 3658cm, which is 1:152 scale - which is pretty much spot on 10mm ground scale. Might have to think about using this now...
The first game we used multi-based figures - a single 50x30mm base with 6 infantry for the rifle team, and a smaller base with 3 on for LMGs, leaders were single based on washers.
But I have been busy rebasing infantry into 2 figures on 30x15mm bases, so that the troops spread out more.
I too will be using 10mm, starting off with Brits and Germans. The plan is to base the figures on 1p and 2p coins, with ATGs etc on small bases.
Wulf
I now have about 6 foot of hedges, 6 foot of walls, 6 foot of fences and about 2 dozen buildings (actually 1 dozen , with whole & ruined versions, thanks to paperterrain.com). I have all the minis I need for a heavily reinforced platoon of plucky Brits and another of the Jerry fit for France in 1940 (all unpainted, sadly...) Biggest problem at present is that my hedges keep falling apart... I need more practice making clump foliage hedges, it seems, but it's cheap enough...
TinyTerrain
I managed to grab 2 games of CoC at the weekend, 1 solo (purely infantry to get a grip of the mechanics ) and 1 with my son (including some support options). An AAR/thoughts/review will follow on my blog later tonight or tommorrow.
In the meantime, I ve managed to paint my entire US Para Platoon (33 minis) in under 3 hours! Just rifles to paint and a quick basing and their done. IT WILL BE RECORD FOR ME..............UNDER 4 HOURS FROM BARE METAL TO FINISHED PLATOON. I know many will say its th wrong scale for them.......but they were kicking aroung in my bits box so were free!
Take a look at the link below for detailsof the method used:
http://wargames.blog.co.uk/2013/09/03/gallery-33-x-15mm-us-paras-painted-in-under-3hrs-16356750/
Craig
Tiny Terrain Models
ronan
That's great !
3 Hours...  =D>
Three hours! That's Nik level speed!  :o great figures btw!
Well done Craig 8). They should look the dogs b*ll*cks when the bases are done.
3 Hours to paint all those   :o
I'm so slow at painting I sometimes think I can almost sculpt faster than I can paint !
Those look great Craig !
O Dinas Powys
Quote from: Ithoriel on 02 September 2013, 08:32:33 PM
WH40CoC: sounds cool to me, but then for me the game is more important than the pieces used  ;)
I'd shamelessly game with naked lead - probably!  :o  :-[
Fab Craig, truly Fab...
I think there is inspiration there for my 10mm SCW collection which is gathering dust. I've got a free weekend coming up I will have to see what I can churn out... ;)
I'm planning on Coc SCW as well with all my spare odds'n'sods. Should make for nice and colourful forces 8).
And it looks like someone has expended some effort on SCW lists which are at the draft stage... 8)
I'm working on a RM Commando list for 44 which is close to completion. Like all lists needs a bit of playtesting and hopefully some support from the CoC rulesmeister in determining the Platoon Force Rating and support lists :)
The Balagan website has lots of useful info on the SCW, so will check this out later. Looking forward to the draft SCW lists that I will also use as a basis for my AVBCW forces using CoC for small scale actions.
TinyTerrain
I still fancy trying my hand at African Bush Wars played with CoC.
Won't be for a while yet though,
Craig
Quote from: Steve J on 04 September 2013, 10:46:50 AM
Agreed, Balagan is useful but it doesn't go down to the finite detail of platoon level structure and weapon allocation which might prove a bit more difficult to pin down. I used Balagan to build the SCW lists for BKC2 but I am more than happy for someone else to do the leg work in terms of CoC ;)
TinyTerrain
US Para Platoon now fnished....3Hrs 55 minutes  :-t
Pics on my blog:
No more painting for a day or 2.....off to the sunny Jura for a couple of days with work  :D
Craig
Tiny Terrain Models
Terrific Craig !! :-bd
04 September 2013, 02:24:05 PM #199 Last Edit: 04 September 2013, 02:27:31 PM by mad lemmey
Hose are really lovely! Bring us back a bottle?  ;)
