Indian Mutiny / First Indian War of Independence Project
Started by paulr, 05 July 2022, 12:01:31 AM
I've been making steady progress on the next batch, details done & skin base coated :)  :)
I also took some pictures during my lunch break while working from home
13th Bengal Irregular Cavalry, from Azimghur
14th Bengal Irregular Cavalry, one squadron from Nowong & Bengal Irregular Cavalry Brigade commander
1st Oudh Irregular Cavalry, of Lucknow & Oudh Irregular Cavalry Brigade commander
3rd Oudh Irregular Cavalry, of Lucknow
A 'brigade' of two regiments of Nowabie Cavalry including their leader
These units are on deeper bases as they are non-drilled
3 Bullock carts, a cart as a barricade & a pair of spare Bullocks
Some baggage to be protected in some scenarios
Painted & Based
395
Foot
128
Mounted
18
Models
  541
Total
very nice as usual  :-bd
Look forward to seeing these guys on the table in due course.
hammurabi70
Quote13th Bengal Irregular Cavalry, from Azimghur
Very impressive.  How is the terrain on the bases done?
:-bd
काफी बढ़िया
You continue to do 10mm honour, sir!
I use a mix of wall filler (spackle), paint and PVA
I coat the top of the figure bases with PVA then spread the basing mixture over the base
The figures are placed into the mixture, it is then smoothed over the edges of the figure base
The base is then dipped into the flock mixture, in this case mainly desert sand with several different grades of ballast as stones
Once fully dry I usually need to touch up the flock in a few places using PVA
Quote:-bd
काफी बढ़िया
धन्यवाद
I've finished painting and touch ups on the now current batch :)  :)
Progress is much faster on a smallish batch of foot ;)
Prepared and washed the next batch, more Badmash and Levies :)
Washed the current batch this morning :)
Final dry brush and first coat on the figure bases done this evening :)  :)
Second coat on the figure bases done last night :)
Current batch sorted ready for basing :)
Next batch on the painting rods, waiting for the weather to improve so they can be undercoated :-w
Finished painting bases for the next batch, including a few spares :)
Glued magnetic vinyl to the bases for the next batch last night :)
Labeled the bases for the next batch this morning :)
Based the current batch :)
Waiting for the wind to drop and things to dry out a bit before I undercoat the next batch :-w
Wind has dropped & its sunny, next batch undercoated :)
Flock touched up :)
I may get some jackets base coated on the next batch tonight, if I can gather the enthusiasm :!!
Didn't gather sufficient enthusiasm last night  :(
Managed to get jackets base coated and dry brushed today :)  :)
Also took some picces of the last batch as it was sunny this afternoon
Badmash - great mob of zemindars, &c, of neighboring districts, who came well-armed to assist the Nana
Two units of non-drilled Badmash and their leader
Badmash & Levies from Cawnpore
A unit of non-drilled Badmash & a unit of Levies
