CWC-II Army List Errata/Suggestions (Closed)
Started by Big Insect, 24 May 2022, 08:54:10 AM
06 May 2024, 08:32:45 PM #320 Last Edit: 06 May 2024, 09:19:36 PM by Leon
Quote from: Huntsm on 05 May 2024, 10:59:48 PMWhy is there no entry for a T62 in the Arab armour list 1956 to 82?
Are there any plans to add it?
Stephen
If you want to add it to your own copy of the downloaded lists whilst the whole errata update on all the lists plus the new additional lists is being processed, please be my guest - just use the stats from the Warsaw Pact list.
The revision work on all of the lists is pending and should be done soon, the delays are completely at my end of things.  Getting ready for Salute took up most of March and then we're straight into two more shows at Falkirk and Partizan.  As soon as we've got some clear water I'll start working through them.
PrivatePikeDa
Looking at the Coldwar soviet army list and just wondering if the T10M was quite so good. Best armour of all Soviet tanks 6 hits, saves on a 3  (same as an M1A1 and better than T80BV (6/4). Ok so the armour was thick but more surprising out ranges all other soviet tanks at 5/110 for AT again compared to the 6/90 for the T80BV
That one's on the revision list, the new stats will be:
T-10M   155   AFV   15   6/60   6/60   6   3   -/- [9]
Would the stats be any different than a 105mm armed Centurion?
Quote from: Lord Kermit of Birkenhead on 07 October 2024, 07:41:41 AMWhen you adding the Vyjanta ?
We are not  :D
It will have to wait until I get around to the full 1947-90 Indian List, and that is way (way) down the list of outstanding CWCII lists.
Quote from: Raider4 on 07 October 2024, 08:34:11 AMWould the stats be any different than a 105mm armed Centurion?
Slightly less armour and faster
flamingpig0
 H.P. Lovecraft
Salah Askar,
07 October 2024, 10:05:46 AM #330 Last Edit: 07 October 2024, 10:10:59 AM by Raider4
QuoteSlightly less armour and faster
Yes, but given the granularity of the CWC system, would the in-game stats be any different?
If you up the speed to 25, that's the same as the Challengers. Really?
I can see more of an argument for dropping the armour to 5, so it would match with M48/M60. I think the later Centurions maybe over-armoured with 6.
Took a hunt but I made it :- 5/120   5/100   3   5   4 Speed is 25 and it has IRNF.
PrivatePikeDa
QuoteThat one's on the revision list, the new stats will be:
Brilliant, Thanks
dylan
Err, isn't the T-10 still 6 hits saving on a 3?  Seems a bit generous.
Jordi
Quote from: Big Insect on 24 May 2022, 11:21:39 AMA Type 56 should in effect be the same at RPG-2 (in game terms).
Both should be the same points (15pts) and both should have the same stats (AP: 3/10 |AT:3/10H)
I'll do a check across all the appropriate lists and adjust (45pts is a typo)  :o
The statsof Rpg-2 are correct for all the lists including NVA and Vietcong
Jordi
QuoteSorry the uppers post war a question.
Ahead of the launch of 'continuity' errata update, I am not publishing any of the revised stats on a 1-off basis.
However, as a general rule, if you think that a stat is incorrect, the best approach is to go back to the same weapon stats in the on-line army list for the manufacturing country (Soviet Union, UK, USA, France, China etc.) and use that as a default.
I am currently stuck in-bed with flu - so this is fullest extent of my answer on the matter - at present  :)
(cough cough cough)
dylan
Quote from: Leon on 06 May 2024, 09:23:27 PMThe revision work on all of the lists is pending and should be done soon, the delays are completely at my end of things.  Getting ready for Salute took up most of March and then we're straight into two more shows at Falkirk and Partizan.  As soon as we've got some clear water I'll start working through them.
It is now mid-2025 and I had reason to go back to this section of the forum for the first time in a long time.  I'm left wondering what happened to the "continuity project/errata/list revision?
