10mm American War of Independence
Started by xccam, 01 May 2020, 02:57:04 PM
xccam
I have started painting up 10mm figures for the battle of Cowpens (1781), at a figure ratio of roughly 1:8, as a bit of a project for lockdown.
I have painted 24 figures to represent the approximately 180 soldiers of the 7th Royal Fusiliers.
The figures are based on 40x25mm bases using the rear 5mm for labels.
I think this gives a good looseness of files suitable for the battles on the North American continent.
Glorfindel
Lovely job, really does justice to Clib's excellent sculpts!
xccam
Thank you for the kind words, I agree that they are fun sculpts, @mollinary!
01 May 2020, 06:28:52 PM #7 Last Edit: 01 May 2020, 06:57:31 PM by Westmarcher
Very nice, indeed! I'm currently reading my Osprey books on the Philadelphia campaign again and, suitably enthused, toying with the idea of starting a small Pendraken AWI collection. In the planning of such matters, numbers of figures and bases are a critical factor. Although my SYW battalions are 32 figures strong, I don't fancy going in so heavily this time and will probably approach unit size from a more 'minimalist' direction (e.g., 3 figs per base instead of 8 ). What rules did you have in mind when deciding on your unit size and basing regime?
M113Grunt
Excellent modeling and brilliant paint work.
 :-bd =D> :-bd =D>
A fascinating battle
Westmarcher, 3 figures per base seems very low. The foot looks best in two ranks
Excellent job on those  ! :-bd
xccam
Thank you all.
@Westmarcher, I don't really have any rules in mind, because the likelihood is that they will likely do much more sitting in boxes than they will do refighting any actual battles. I did mock up a quick ruleset which I may try to properly finish bodging together once both sides are completed, but that was more to help sketch out what I wanted to do with the figures and labels.
As for 8 to a base and 24 figures, I think 8 looks nicely spaced on those sized bases and at 1:8 figure ratio the 7th at Cowpens would be 22 figures and I see no harm in the extra 2!
Shutuphippie
2018 Painting Competition - Winner!
Noktu
Good contrast achieved with the painting and basing!
Ace of Spades
Beautiful figures, a joy to paint. You certainly do them justice!
Rob
Those are really beautiful.
I reflect that I've hardly lifted my brushes since the lockdown has begun.
Currently front of the queue are 15mm Indians (For Dragon Rampant) and 2mm Renaissance.
I've a cunning plan to save my £18.00 non-spend on railway tickets and use it to launch my 10mm Irregular Wars contingents.
xccam
Thank you for all the kind comments.
First update of figures added since then -
The first 3 bases of the 71st Fraser's Highlanders
A 3-Pounder
Here is a group shot including the first 3 bases of the 7th Royal Fusiliers, 71st Fraser's Highlanders, Legion Cavalry (but not the 3pdr)
They look great !!  :-bd
