ECW project - For King and Parliament
Started by paulr, 28 June 2018, 08:11:23 AM
Finished base coating non-uniform jackets on the next batch :)
Base coated about half the non-uniform trousers :) :!!
The current batch was varnished early this morning before the wind got up again :) #:-S
Finished base coating all the non-uniform trousers on the next batch :)
Dry brushed all the jackets and trousers on the next batch :) :)
And I took some picces ;)
White Auxiliary Regiment of the London Trained Bands
White Regiment of the London Trained Bands - 2 units due to size
'English' Painted and based
    913 Foot
    352 Mounted
      15 Guns
1,280 Total
Continue to applaud you taking the time to put these guys in mufti! Excellent look.  :-bd :-bd
Terrific work, yet again, Paul.  =D> :-bd =D>
Thanks all :) :-[
Quote from: d_Guy on 02 February 2019, 03:50:50 AM
They're Trained Band, i.e. militia, of course they have to be in mufti, their drill is a bit rough as well ;)
Hats, shoes and boots base coated :)
Hats and boots dry brushed :)
Both sides painted on the hedge bases :)
Sabots assembled and both sides of sabots and bases painted :) :)
Too hot again this afternoon to paint so prepared the next batch, 6 units of Royalist Horse :)
Scabbards and belts done :)
Woodwork done :)
Made a start on the hat bands :)
Edges of sabots and bases painted and sabots labeled :) :)
Clump foliage glued to hedge bases :)
Waitangi Day holiday in NZ today.
Got some spare time so started sorting out 300+ figures for 12 highland battalia.
I mainly used figures from Pendraken's 1745 Jacobite range plus some Highland archers from the C16 range since bows were still recorded as being in fairly widespread use in Scotland up to least 1640.
They are all very quick and easy to clean up, just little molding marks on the bottom of the bases to remove to make sure they stand up correctly. Only additional thing I need to do is remove any bayonets from the 100 odd musket armed figures since bayonets were only introduced in the 1680's (plug bayonets were first widely used by the British army at Killiekrankie in 1689).
Assembled more bases for the highlanders.
Sourced some good kapok quilt filler to use for smoke markers from offcuts in Mrs Shy's material stash  :)
I'm also making good use of the Waitangi Day holiday :)
Metal work base coated and highlighted :) :)
Hat bands finished and sashes done :) :)
Drums done :)
Bags and 'apostles' done  :) :)
Skin base coated :)
