Rules for Mongols ?
Started by Albie Bach, 25 November 2013, 08:55:01 AM
Albie Bach
I've just read the first of a series of articles in the latest Miniature Wargames magazine about the Mongol conquests and was wondering what rulebooks do you think would be good for the new Mongol range?
I've had a look through various topics about the Mongols and can't find anything about it.
Cheers, Colin
I haven't played them, but I have heard good things about Ironbow from the Perfect Captain. They are designed for the Crusades but cover Mamluks and Mongols.
http://perfectcaptain.50megs.com/ironbow.html
Warmaster Ancients covers the Mongol period, as does Hail Caesar IIRC.
Just thought of Fields of Glory which may cover said period.
Albie Bach
Quote from: Steve J on 25 November 2013, 09:16:31 AM
Thanks, Steve
Warmaster Ancients rather than Warmaster Medieval you think? Are they in the Warmaster Ancient Army book do you know?
get2grips
Hi Albie,
They are in the Warmaster Medieval book.
If you ever need to chase a WM army list, check here ;)
http://www.ricks-warmaster.com/ricks_lists.htm
Shedman
The problem with Mongol warfare is that it quite fluid and requires space
In Field of Glory the Mongols require a 6x4 table to be any good, smaller tables ie 5x3 in some competitions, don't leave any room for flank attacks or running away
I won a FOG  V1 Competition using a Mongol Conquest army. My opponents were Jin, Republican Roman, Indian & Catalan Company
In each game it was a case of exploiting the rules to get the enemy to chase me in all directions and then picking off isolated units
FOG V2 is a bit different as it no longer requires units to chase after Light troops - I maybe wrong as I gave up on FOG and haven't played it
I've used Huns with Warmaster which allows cavalry to zoom around the table - no doubt Hello Caesar works in a similar fashion
As I intend to do pre-conquest Mongols ie Mongol against Mongol, I am tempted by Warmaster, HC or Battles For Empire or a combination of all 3
get2grips
Quote from: Shedman on 25 November 2013, 09:59:49 AM
Agree completely.  Can't comment on other rules but WM (on a BIG table 6'x4' at least) allows battle changing manoeuvre.
Basic Impetus has a nice Mongol Army in it
Warmaster Medieval is just an army list book with some extra rules for the period, so you need the Warmaster Ancients rulebook as well to play the game. However you certainly get a lot in each book, especially stuff for campaigns, seiges etc, the former which you really want for the rampaging Mongol hordes I would have thought. He this helps?
I was going to use Hail Cheesy, as the army list limits mongol light horse to small units.
Planning on Mongol vs mongol to start with.
Albie Bach
Quote from: Steve J on 25 November 2013, 10:42:41 AM
Ah right, thanks. I didn't know that.  :-[
Yes, the article says its important to get these things right to represent a Mongol force properly.  :)
The new figures look super, but I have to say I have always found light-cavalry specialist armies rather dull to use on the table. Effective, if the table's big enough, but dull. I've done Parthians, Scythians, Magyars, Palmyrenes, Huns, Mongols, Sioux, and Hsiung-Nu in my time, so I have honestly tried.
TinyTerrain
Hi,
I am currently writing "The Crescent and The Cross",  my 10mm rules for the Crusades. However they could easily be used for Mongol shananigans  :D just by adding some troops stats and army rules. The core rules will be available early next year all being well.
Craig
Tiny Terrain Models
Albie Bach
Thank you for all the info and the links. The summary list is:
Warmaster Ancients
Hail Caesar
Fields of Glory
Battles For Empire
Basic Impetus
Perfect Captain - IronBow
and Craig's "The Cresent and The Cross" rules he is working on.
I'll have a look at any I can get hold of and take it from there.
It's a great looking range and not something I had considered until I saw the new masters and interest on this forum.
Shedman
I should warn you that Battles For Empire is a set of 19th Century Colonial rules
I just happen to use them for Ancients
Albie Bach
Quote from: Shedman on 25 November 2013, 04:39:36 PM
Noted. As it happens I had a scan of them last week and did wonder about that.
Thanks for the warning anyway.  :)
Sandinista
I plan to use Pike and Shotte, have used them for 16th century Turk v Persian and they give a good game
Hello Albie Bach
I'd also recommend Iron Bow (I'm a big fan of the Perfect Captain) and there is a new campaign system, Princes of the East II, coming out which will include the Mongols.
Also, although I haven't seen them, if you are a fan of Chris Peers' wargame rules there is Empires of the Steppes http://www.spiritgames.co.uk/single.php?menu=3&sub=19&tagno=7504&game=11424
Albie Bach
Thanks for those. I'll update my list to look at.
