Paper Buildings
Started by barbarian, 13 November 2013, 08:19:16 AM
Can you still get foam-card (foam-board ?)....That'd work quite well to reinforce the paper, I'd have thought. :-\
Wulf
I got some from an art supplier in Greenock - which unfortunately shut up shop about a year ago...
GordonY
Yeah you can still buy it on E-Bay, but cardboard has the advantage of being free.  :P
barbarian
I think the main advantage of the DZC buildings is that they are stackable to save storing space.
Wulf
Quote from: GordonY on 19 November 2013, 10:05:15 PM
It also has the advantage of not paying postage on sheets of A1, which is how I bought them...
Wulf
As I've mentioned, I usually use the pre-printed buildings from paperterrain.com, but they do have one great disadvantage. They come with an exterior complete building & an interior ruined building - lift the complete version off to reveal the ruined one. There's an interior printed on the 'back' of the interior sheets, so you can place minis inside it. This looks great on the table, but means the walls are... well, paper thin... Thick paper, mind you, and with the exterior in place they're sturdy. But I wouldn't like to use the 25/28mm versions, they'd look flimsy and indeed would BE flimsy...
barbarian
About the thin walls, a 60 cm wall in real life would be a 0.4mm at the scale 1/150, so paper is good for the little scales.
Quote from: Techno on 19 November 2013, 05:39:23 PM
Yes, Hobbycraft do it in several sizes. It cuts more easily and accurately than cardboard, I find.
What i have done in the past, is glue matchsticks cut to size to the inner side of the wall.Just score the middle of the 2 matches with a hobby knife. Do this until the matches fit each other in a cross shape and glue them togheter and attach to the walls.
I find this makes them more durable. Off course you can only do this on buildings wich are closed.
