To the Last Gaiter Button
Started by dedonta, 27 August 2013, 02:20:46 PM
dedonta
Anyone have suggestions on how to do the 10 inch terrain squares and make it look nice?  I'm struggling with how to approach this.  Thanks
Personally D, I'm afraid I can't help.....But there'll be someone along fairly shortly to give you a hand, I'm sure.
But......As that was your first post.....
A very warm welcome to our happy forum.
Have considered using vinyl flooring with tile effect. This can be sprayed and/or flocked and the squares will still show. All terrain will have to be free-standing.
dedonta
Thanks Techno...didn't realize I had never posted lol.
Vinyl tiles is an interesting idea.  Plenty of earthy toned options out there.  May take a look into that.  I was also considering Hotz Matz and getting the square grid printed on the mat.  But he only goes up to 6 inch squares.
Peter Pig do corner markers for their square bashing ranges.
A fiend got a load of tester pots in 'rural' colours and painted up a board in squares, it looked pretty cool.
Try TSS
http://totalsystemscenic.com/index.php?main_page=index&cPath=1028_1284_1267
Terrain tiles. I have loads of these in the loft. Must dig them out but cant seem to get to grips with TTLGB :(
Bernie
Try single trees, broken limbers, dead horse etc to make your squares.
Have seen it done with different coloured felt squares from fabric shops
Bernie
dedonta
Quote from: Bernie on 27 August 2013, 04:30:00 PM
Bernie
What a great simple way to do it....thanks...i'll give this a go
I painted subtle dots for my PBI board at the required grid spacing, and then I was able to place trees on junctions, fields at the edges etc to help define the area, but not make it too geometric.
DON'T use the top side of the tiles.  I stick green paper to the self adhesive side - I use for bases.  I use a mixture of cheap green paint (from the cheapie bookstoor) and pva glue.  Spread cover deep in flock, leave 24 hours. Shake off excess and spray varnish
Shecky
I struggled with the same problem for a while until i hit upon an idea that worked for me. I bought a 6'x4' terrain mat from The Terrain Guy, who happens to be the owner of my FLGS.  I made a subtle mark every 10" on each edge. To be honest, since a 6x4 terrain mat is actually 72"x48" I fudged a bit to get 7 squares by 5 squares.  I then cut a bunch of string into 5' and 7' strips. I taped a piece of string from one edge mark across the mat to the corresponding other mark until I had a grid. Where the strings intersected I made a subtle mark with a black permanent marker, so that the corners of each square were identified. A simple process which probably took no more than an hour to complete. The marks are subtle enough that I can use the mat for other games.
As an alternative to vinyl try using carpet tiles. They come in all sorts of colours and they're easy to cut with a sharp knife. The dark yellow, light green or dark brown ones also look more like fields.
dedonta
All great ideas...thanks folks!  I can't wait to try these rules out.  They seem so different that they are actually very refreshing.
dedonta
Has anyone played with the Republican rules that they released?  I may pick them up as well.
Quote from: dedonta on 28 August 2013, 05:35:54 PM
. Bernie is the guy to tell you, he wrote them, and did the demo game at SALUTE!  I really love the TTLGB rules for big battles, and have written on here before about their advantages and subtleties.  I wouldn't get too hung up about the exact size of your squares, though.  Remember, the key intent of the author is that the area represented is one square kilometer, and that the most units it can contain effectively amounts to about a brigade.  As all measuring is by the square,  you can adjust its size according to your whim, and the size of your troop bases.  For my games, I have reduced the infantry base sizes to 25mm wide, not because of size restrictions, but because I think it looks better.  I think you could easily get away with squares from 9"-12" if you wanted, and even smaller if you were using 6mm figures (which, of course, you will not be!  ;) ;)).
Mollinary
