Varnish Spray
Started by Thaladan, 12 January 2013, 05:20:18 PM
Thaladan
Hi all,
Can anyone recommend a varnish spray for Pendraken models? Also, your opinion on matt vs gloss?
Welcome aboard Thaladan !
I'll let some of my esteemed colleagues point you in the right direction regarding 'brands'
From a completely personal point of view, I prefer to see matt rather than gloss as a finish....But when someone pops in with a more definitive answer, it may well be that folk will give the figures a gloss varnish to help protect them, first and foremost.....Then....Once the gloss has thoroughly dried... 'dull them down' with a good matt spray.
C'mon chaps...you'll know the best of the current crop of varnishes better than myself.....My tins must be around 10 years old by now.  :)
IF it's still available.....I never ever had a bad spray can of Letracote Matt.
Windsor and Newton matt fixative every time.
Rob
Hi Thaladan and welcome,
I have moved away from spray varnishes, I have found the effects vary too much over different applications. I now use a Windsor & Newton bottled matt acrylic varnish - GALERIA. I am very satisfied with this and would recomend it.
Cheers, Rob  :)
AndyT
I use Vallejo spray gloss varnish then when it has had a good period of time to dry thoroughly I apply Army Painter matt spray varnish.
However I might have to change my brand of gloss varnish as I could only get it in spray cans from Maelstrom Games which is not an option any longer.
Bernie
Dullcote or Army Painter Matt Varnish a can do 100's of bases
I've always found that the Vallejo matt varnish goes on fine every time and gives a good matt finsih. I do brush it on though.
NTM
Windsor & Newton Matt brush on for me too. Discovered it years ago and never even considered anything else since. I prefer the Artists one to Galeria though, recently bought a new bottle and find it even better than before.
GordonY
Nah sorry lads but you can keep all those mentioned above, nowt beats a good spray with Dullcote. its the flattest finish in the known galaxy (and Croydon).
Quote from: GordonY on 13 January 2013, 07:49:53 PM
Dullcote's my preferred one too - it'll take the shine off of chrome...can be hard to get hold of though, so Army Painter Matt is my (close) second choice  :)
quasar42
Testors Dullcote for me too. But I would recommend using a gloss varnish first (and wait until dry) before spraying with Dullcote for two reasons: (1) Gloss varnish is harder and therefore adds an additional layer of protection and (2) I understand that without the gloss varnish Dullcote may damage the paint because it is a lacquer (although I luckily have no first hand hand experience with such a disaster - fingers crossed)
AndyT
Quote from: quasar42 on 15 January 2013, 05:06:04 PM
I've sometimes seen what you might call "paint bleed" after varnishing - colours merging, even when they have had a long time to dry, often turning white paint into a mixture of surrounding colours and especially when using inks for shading.
However, I think a good varnish enhances and gives depth to colour.
Chad
Gave up on spray varnish and now use Vallejo Matt and brush on.
Chad
