It's Official! Saddest man in world discovered in Belgium.
Started by mollinary, 01 September 2012, 05:47:20 PM
Yes, folks, it is I - not Le Clerc (raising spectacles) but I, Mollinary ( raising spectacles).  I have just pronounced my latest project a success. What is to, you ask?  Well, I 'll tell you. It is the production of completely blank bases.  Yes, COMPLETELY blank.  One almost feels they should come in a brown paper wrapper.   Since megalomania took hold, I have collected large armies for the hyphenated wars.  Although the vast majority of the painting is outsourced to the brilliant Sri Lankans who work for Fernando, I reserve the basing for myself. And I produce movement bases, of card and magnetic tape, to help move the vast legions.  But what, the inquiring of you ask, do you do when casualties are caused and the movement bases are exposed. Well, until today, the answer would have been "if you don't like the look, you can always take the bases off  and move them individually if you really want!".  Silence usually follows, and knowing looks are exchanged as the photographer approaches.  Well no more.  I have discovered the production line technique for making blanks to replace figure bases removed from the movement bases.  Humbrol's Sea Grey is the secret, in spray form, which allows my simply PVA d and sanded metal bases to leap to fully prepared and under coated blanks in their hundreds, in seconds.  Once dry, drybrushing withVallejo stone grey is a doddle, and then the sticking of flock to match the terrain is again very quick. They match my figure bases perfectly, and will shortly be home to my casualty markers as well.   How sad is that? I am spending my time, valuable time, producing beautiful bases - with nothing on them.   I'll get my coat.
Mollinary
If anyone asks you could say there terrain pieces representing the area around Dixmude
You know, it could double up for modern roads too! Damn, beaten to it!  ;D
Mock, mock!  All true prophets are mocked in their own lands!
Mollinary the Seer
I thought it was a compliment ..I like it round Dixmude, the museum there is fantastic
and from the top of it
So, the story rapidly comes to a close.  Only a day after beginning the process, I have 100 25mmx20mm, completed, naked, bases.  And done in off time, watching TV, cooking, reading.   And so, with luck, this sad phase comes to an end - but when will it return?  The dark shadow hovers, awaiting its moment, to .....................?
Mollinary
So where are the photos? As someone once remarked, Mollinary, if there are no photos it never happened.  ;)
