Michaels 10mm 1809 BLOG
Started by WeeWars, 01 May 2012, 10:55:13 PM
Quote from: WeeWars on 09 January 2013, 04:48:54 PM
Phil, Don't forget what I said back in November: "Look forward to seeing the results!" I'd be interested if you discover a new way to keep the stuff warm to avoid water and air messing up the mould.
;D ;D ;D
I can't show you yet Michael....I'm using the process for something 'hush hush' at the moment.
But....I'm letting the putty set (relatively quickly) by leaving the whole 'kit and caboodle' on top of a radiator.
I have been tempted to put in tiny vents with a pin.
What I love about Instant mold is that you can see through it to see where the putty hasn't filled the cavity.
So far I've said 'sod it'....Let it set...Then 'repaired' the 'casting' with minute amounts of putty. ;)
WeeWars
Quote from: Techno on 09 January 2013, 05:56:02 PM
Your secret is safe with me - and the rest of the Forum.
www.supremelittleness.co.uk
WeeWars
I'm trying to avoid those lines you get as the mould bunches up on itself. I think that's where keeping the stuff warm helps.
At the moment, with what I'm using it for.... that particular problem isn't an issue Michael  ;)
No....no hints......yet !! ;D ;D
I'm still experimenting really....But it appears to be working as I want already !
Hey, having browsed your really nice blog before, i can only say keep it up!
However, from the moment you said you changed it up can no longer see it. I get as far as "enter" and that's it.
WeeWars
Quote from: petercooman on 10 January 2013, 12:16:27 AM
I guess that you still have the original enter screen in cache memory. Try reloading the page - right click, reload - and see if the page changes. The clue is that the old page with the Flash movie was 1809.html, the new one 1809.htm.
Let me know if that works. Cheers, Michael
13 January 2013, 11:08:28 PM #106 Last Edit: 13 January 2013, 11:10:44 PM by petercooman
Nope can't get it to work, this is the one i use:
http://www.michaelscott.name/1809/1809.htm
That's the one i get if i push the website button in your post.
Maybe post a link here with the next page after the 'enter button' bit. Maybe it's that one that doesn't work with me.
WeeWars
Peter,
Your pasted link works for me. Did you try reloading? The new link can still access the html file in your cache memory if you haven't. Here is the 1st Post page link:
http://www.michaelscott.name/1809/1809overture.htm
Let me know how you get on. Cheers, Michael
WeeWars
New year, new posts. Starting off with Post 61:
http://www.michaelscott.name/1809/1809blogpost61.htm
Other new posts on 10mm tree bases.
Cheers, Michael
Nice looking trees, Michael. Woodland Scenics are great so long as you don't move them about too much. I find they have a tendency to moult if handled too often. I've tried every type of adhesive from superglue through to contact adhesive and sprayed them with everything from watered down PVA to hairspray. Nothing works definitely, not even the stuff Woodland Scenics sell themselves. Don't handle them if you can possibly avoid it, is my advice.  :(
WeeWars
Quote from: Hertsblue on 18 January 2013, 09:21:06 AM
http://www.architectsofwar.com/Howto/BigTrees.pdf
If you scroll down this Architects of War PDF you come to Making Tree Foliage More Sturdy - "able to handle the rigors of gaming". I thought I might try the dribbling Scenic Cement technique. Guess you've already tried that.
WeeWars
WeeWars
Post 65: Pendraken chasseur à cheval elite company trooper simple conversion.
http://www.michaelscott.name/1809/1809blogpost65.htm
Cheers, Michael
Nice work Michael ! :-bd
Quote from: WeeWars on 18 January 2013, 01:43:58 PM
That's a good spot, Michael. I may just try that.  :)
Thanks for the change, Michael, I can now access your wonderful blog from my iPad2.  Great work!
Mollinary
WeeWars
Quote from: mollinary on 19 January 2013, 12:05:53 PM
Hi Mollinary,
That's really good to know. There is much to recommend Flash but HTML reaches all the places Flash fails to reach! I think it was worth the rebuild just to include as many platforms as possible - including Mac devices!
Cheers, Michael
Rob
Quote from: WeeWars on 18 January 2013, 08:56:50 PM
Cheers, Michael
Love the conversion Michael.  :) For interested if you want elite companies in the French  dragoon regiments I am using troopers from the Carabiniers pack.
Leon would it be possible to have these as and addition to your ranges?  :) An of course Hussar eleite companies.  :) :)
