Making My Own Dungeon World Tiled Dungeon TableTop
Started by sixsideddice, 09 May 2011, 01:31:41 PM
It is isn't it. The 1 inch sheets go for around £8, don't why the smaller ones are so much more expensive.
I'm going to have a look in B&Q next time I'm in to see if they have any seconds / damaged ones going cheaper.
O Dinas Powys
Quote from: Leon on 09 May 2011, 04:07:16 PM
Quote from: sixsideddice on 09 May 2011, 04:06:38 PM
.... maybe cast smaller flat sections which can be placed side by side together to form a larger whole?
:)  <--- ever hopeful
That's definitely an option...
With walls that can be added around the edge?
...and whilst we're getting wistful, longer corridors?
Yeah, something like that.  Making a large tile, say 6 inch square, would be easy enough to do, and then we could look at making some intact/crumbled walls in a variety of options.
All of the above relies on me finding some spare time to have a go though!
O Dinas Powys
Quote from: Leon on 12 May 2011, 10:36:21 PM
Doesn't it always?   :'( ;)
Maenoferren
Quote from: O Dinas Powys on 12 May 2011, 10:24:24 PM
is this the kind of thing you are thinking of....i know this is water caverns but you could use a similar principle:
http://www.hirstarts.com/cavern/watercavern.html
O Dinas Powys
Quote from: Maenoferren on 15 May 2011, 10:47:26 AM
Not really, I was thinking far more conservatively  ;)  However, if something like that was to become available...  :D
My idea was the current floor without walls in a few sizes (from 2x2 up to HUGE) with the current walls as separate edging.
Three types of edge: open ended, inward corner on one end and outward corner on one end, say multiples of 3-squares long with a 1 square strip of floor sections for stability.
With these bits you should be able to construct irregular rooms and surround them in a wall to fit in with the available dungeon pieces, which would help lock in the wall segments.
