Basing for Crossfire and O-Group (WW2)
Started by Berggeit, 01 February 2026, 12:31:47 PM
Berggeit
I am thinking about getting into Crossfire as my first proper forray into historical wargaming and 10mm seem ideal for it. I think it might also be a good jump off point into O-Group.
I am curious about reconmended base sizes (going with round or oval) or reconmendation based on the number of figures (it would be nice to order everything in one go).
A basic force would have:
  • 1 x Company Commander: 2 figures
  • 3 x Platoon Commander: 1 figure
  • 9 x Sections: 3 figures
  • 1 x Forward Observer: 1 figure
  • 1 x Mortar Team: 1 mortar and crew
  • 1 x Machine Gun Team: 1 machinegun and crew
Still deciding on the theather/battle:
- Normany Campaign
- Operation Market Garden
- The Battle of the Bulge
- Invasion of the Netherlands (Polish infantry seem like a good proxy for the Dutch infantry)
Welcome. Your basing would work for Cross Fire, but O Group is a skirmish game with 1-1 repersentation. As to campaigns Normandy and MG would be exactly the same figures.
I can only comment for Crossfire.
I'm the sort of gamer / collector who provides both factions when hosting a game.
This frees me from the written basing conventions when they don't match my table dimensions.
Working in 10mm, I'd follow this line of thinking:
0. How big is my playing surface.
    Consider Crossfire is a terrain hungry system.
    Your table might accommodate 6' x 4', but you may only own enough trees for 3' x 3'.
1. How many bases, and what area of storage can I devote to this?
     Storage is a big issue for me - if not for you, then crack on.
     I would select 30mm or 40mm squares as the basis of my forces - I use 40mm squares for my Irregular Wars forces.
2. How many figures will look good on a base.
    Here 10mm permits rather more figures (especially on a 40mm base).
    I'd be inclined to 5 or 6 figures for a squad or company command and 3 for a team or platoon command.
Quotebut O Group is a skirmish game with 1-1 repersentation.
I disagree.
We played O Group with my WWII figures based 5-6 figures on 50x30mm bases.
For O Group one unusual thing you need are some patrol markers - I went with 2 figures on 40mm circles - so they stood out from the standard infantry bases.
QuoteA basic force would have:
Are you aiming to go with the fewest figures and smallest bases practical, so you can play in a small space? If not I'd be adding 1-2 figures per base.
Whilst 1x 10mm foot figure on a base is possible it is a bit small and fiddly.
Berggeit
Thank you for the quick responses!
@Lord Kermit of Birkenhead
QuoteWelcome. Your basing would work for Cross Fire, but O Group is a skirmish game with 1-1 repersentation. As to campaigns Normandy and MG would be exactly the same figures.
Thank you! I wouldn't really call O-Group a skirmish game. Maybe big skirmish? I think you can play both Crossfire and O-Group as 1:1 or abstracted.
The way I see it, with my current system. I would just need to get 18 more sections, two more company commanders to go from a Crossfire company to O-Group battalion. Of course it would also require some more other options (artillery, support weapons, vehicles, battalion commander) etc.
  • 1 x Battalion Command: 3 or more figures
  • 3 x Company Commanders: 2 figures
  • 27 x Sections: 3 figures
  • 9 x Combat Patrols: 3 figures
  • 1 x Forward Observer: 1 or 2 figures
  • 1 x Jeep/Bike for the FO: 1 vehicle
  • 3 x Machine Gun Teams: 1 machine gun and crew
  • 3 x Mortar Team: 1 mortar and crew
  • 3 x Anti-Tank team: 1 anti-Tank weapon and crew
  • 3 x Field Artillery: 1 field gun and crew
@steve_holmes_11
QuoteI can only comment for Crossfire.
I am also collecting both factions. For the moment I am a solo gamer.
  • My table is 3' x 3' but it can be increased to 5' x 3'. Still have to make terrain.
  • Storage isn't going to be an issue for the figures.
  • I have already settled on 3 figures for a standard infantry base. A matter of cost and board size.
@fred.
QuoteAre you aiming to go with the fewest figures and smallest bases practical, so you can play in a small space? If not I'd be adding 1-2 figures per base.
That is correct, as mentioned in my reply to steve_holmes_11.
I am probably going to base 1 and 2 figure's on the same base size.
I would assume for the base size something like:
  • Platoon/Company Command/FO: 20 mm
  • Section: 25 mm
  • Support: 25 or 30 mm
  • Combat Patrol: 40 or 50 mm
Maybe @Leon can divulge the base sizes they used for the WW2 Polish MG, Anti-Tank, and mortar team as well as the enigneers, truck, and artillery/field guns. Those look really neat.
Berggeit
I found a Reddit post about base sizes.
I am going to use 20mm bases for commanders, 25mm bases for infantry and light support (mortars, MG's, and man-portable anti-tank), and 50mm bases for combat patrols.
I suppose I'll just order a couple of different size bases for heavy support and tanks to see what fits.
Regarding the theatre, I am going with Normandy. The bocage seem ideal for Crossfire, easy and cheap to make.
Now to decide whenever I will go for the Yankees or the Tommies for the allies.
