Brushes used for dry brushing
Started by far4ngn, 19 October 2025, 09:46:14 PM
far4ngn
Anyone have a recommendation for some new dry brushes?
Are Pendrakens flat brush range any use for dry brushing?
I tend to use old worn-out brushes for most of my dry brushing
I also use a one-inch flat artists brush for dry brushing dust. I sparingly put the paint on one side and brush the figures with the other side
Ignore me if I'm teaching you how to suck eggs
far4ngn
Thanks...I don't have many worn brushes my recent ones have lasted a few years Kolinsky Sable from Acorn Models in Christchurch.
I use a flat synthetic one buys it's wearing out as I dry brush my bases.
May have to pop into Whitcoulls in the Wellington.
Like Paul, I use worn out brushes for dry brushing but I also buy cheap brushes from The Works, Tesco and similar. For large scale dry brushing I have a couple of makeup brushes.
QuoteAre Pendrakens flat brush range any use for dry brushing?
In general I agree with the others, but to this point, yes they are good for dry brushing, and I often pick up a couple for this purpose.
19th century octopus
I use a fairly massive flat brush. It's maybe 20mm across and about 3mm thick. I haven't used the pendraken flat brushes but would imagine them to be pretty similar, if smaller.
I often dip only part of the brush in paint for 10mm models, unless I'm doing a lot of them, so such a large brush probably isn't necessary for 10mm anyway. If you're doing scenery though, having the larger brush is nice, but not necessary.
