Penal Troops - Mine Clearing
Started by richafricanus, 14 June 2025, 03:03:05 AM
richafricanus
Hi there, some of the Russian lists allow "Penal Troops - Mine Clearing" but I can't see anywhere in the rules (or on the forum) detailing how these work to clear mines.  Thanks for the help.
Probably you walk them forward until they get to the other side of the minefield.
If they're lucky
That's exactly what you do  :)
You dice for the effect of the mines for each 5cm they advance through the minefield.
For each 5cm they move they effectively clear the mines. If they are KO'd they path they have cleared remains cleared behind them. So you will, in effect, always get 5cm of cleared minefield regardless of whether the unit is KO'd immediately or not. The unit can be suppressed just the same as any other units.
richafricanus
Jordi
Quote from: Big Insect on 14 June 2025, 03:37:42 PMThat's exactly what you do  :)
Sorry in page 55, it daus that is cleaned a 2cm x 2cm space. Wich is correct?
Quote from: Jordi on 06 March 2026, 11:15:11 AMSorry in page 55, it daus that is cleaned a 2cm x 2cm space. Wich is correct?
If the rules state it is a 2cm by 2cm clearance zone - that is what it is.
