Greco-Persian and Peloponnesian Wars
Started by paulr, 01 June 2025, 08:32:49 PM
Painted most of the detail on the second 6 units :)
Need to finish the crew :!!
Assembled most of the next 6 units, ataphract triremes this time :)
Keraunos
This is all looking very exciting.  On the question raised earlier about which way round the rowers face, my recollection from the reports of the Olympias trials is that while the rowers would normally be seated facing the stern, it was perfectly possible, with training, for the rowers to change facing - moving back a row of seats, not turning round in place - and row in the opposite direction.  The ship would go in reverse almost as fast as it would go forwards.  This would explain how the 'anastrophe' manoeuvre, rowing towards the enemy and then backing away, trying to lure them to break line, may have worked.
I now have my Lasercraft items and I'm very impressed.
The lembi are tiny but will be very useful. I'm still debating whether to use the corvi on the quinquiremes, they were so short lived that I will probably leave them off. The single deceres will get an escort of a couple of lembi on the same base.
The Roman marching camp is just brilliant, the trench around the camp is cut into the base. The siege train contains a siege tower, two rams and multiple catapults of several designs. More artillery than I expect ever to need .... but who knows.
As well as the items I ordered there was a little pack included containing a fishing village, a strip of wagons and a strip with three onagers and some crews.
If the gout in my fingers would just let up I could see if I can do half as well as Paul with these.
I've said it before, but sympathy with the gout. The condition is no joke.
I've made good progress on these, I've finished painting the first 12 units of triremes :)
I've assembled 12 units of ataphract triremes and nine units of penteconters :)
Triremes have two base coats on hulls and oars  :)
First base coat done on the hulls of the penteconters :)
Once my sea cloth arrives, I'll know what blue I need to paint the bases
Primary and secondary trin colours done on the triremes :)  :)
Second hull base coat and both base coats done on the oars of the penteconters  :)  :)  :)
Details done on the triremes :)
Primary and secondary trim and details done on the penteconters :)  :)  :)
Touch ups done on triremes & penteconters  :)  :)
12 more units of triremes prepared and assembled :)
First base coat on hulls done :)
Second base coat on hulls and both base coats on oars done  :)  :)  :)
Primary and secondary trim done :)  :)
My sea mat arrived yesterday :-bd I'm really pleased with how it looks :-bd  =D>  :-bd  =D>  :-bd
Due to train disruptions (ice on the overhead powerlines) I worked from home today
Popped out at lunch time and bought dark blue and light blue paint that would match the main two colours on the mat
Painted some test bases with the dark blue, not quite the match I was hoping for :-\
After work popped out and got the other dark blue I had been considering, a much better match #:-S  :-bd
Painted the other side of the test bases and will try some wave effects this weekend
Ray Rivers
Looking forward to see the result!  :)
Quote from: Ray Rivers on 25 July 2025, 12:29:29 PMLooking forward to see the result!  :)
So am I  :-SS
Tested wave effects and I'll be dry brushing them
Washed the fully painted galleys
27 July 2025, 03:57:50 AM #52 Last Edit: 27 July 2025, 04:18:18 AM by paulr
I've been focusing on painting the bases of the fully painted galleys :!!
I've done the first 16 units and have done the edges and two base coats of the next 17
Here a few pictures of some of the results on my new sea mat
The mat has a 10cm grid to help give a sense of scale
Your ships are looking good, Navarchos!
Excellent match between mat and bases.
Easy to distinguish the aphract and cataphract ships even at that scale.
Lovely work 8). Personally though, having the oars in different alignment to the bow of the ships would do my head in when looking at them on the table!
QuoteLovely work 8). Personally though, having the oars in different alignment to the bow of the ships would do my head in when looking at them on the table!
And yet having each ship at the same point in the stroke as all the others would be as bizarre as having each man in a battalion in exactly the same pose at one time .... oh! wait!  :)
Really like them!
That you went to the trouble of making subtle changes in the tunic colours of the oarsmen is impressive attention to detail.  :-bd
Thanks, I've added wakes at the stern and behind each set of oars to assist with orientation.
Also, in action each unit will have a small label protruding at the rear showing side, squadron and key stats for the unit.
QuoteAnd yet having each ship at the same point in the stroke as all the others would be as bizarre as having each man in a battalion in exactly the same pose at one time .... oh! wait!  :)
My preference is for variation of pose particularly when actions aren't synchronised, for examples horses and the stroke of different galleys.
I'm happy to have the same (or similar) poses when things are synchronised, for example men marching in step or the stroke on a single galley ;)
During the week I painted some 2mm MDF bases for some markers, glued labels to them today
Painted crew tunics on a couple of batches of galleys :)  :)
Cut out and painted the edges of label cards for a test game (or two) next weekend :)  :)
Glued printed labels to the label cards :)
The label cards are cardboard and go under the units with the printed label protruding at the rear showing side, squadron and key stats for the unit.
12 units of Cataphract triremes completed so far. Plus the 2mm MDF markers
12 units of Aphract triremes completed so far
9 units of Penteconters (all I'm planning on)
