Concealed troops & Visibility
Started by richafricanus, 09 March 2025, 05:14:21 AM
richafricanus
On p.15 it says Concealed troops can only be seen when:
* They open fire, or move along, or out of cover
Does this over-ride the rule that low profile troops in high terrain can only be seen from 5cm away?
So for example, my ambush in a high terrain forest fires at enemy 5cm away.  Can the troops in ambush now be feared on by a tank 60cm away?
And then related to the above, subsequent to the above action, my troops who were in the ambush move so that they're now in the middle of the forest.  Can they still be seen and targeted, as they fired in a previous turn?
We've always played that once units have fired they are visible (i.e. placed on table as other units are).  But they are still subject to normal Line of Sight rules.
So your unit in the middle of a wood, wouldn't be visible, because you can't draw LoS into the middle of the wood.
richafricanus
Fred is correct
Ambushes are revealed when the units in them are placed on-table, fire or move or the enemy gets close enough to trigger them.
Units on a hill cannot see into a high area terrain piece other than at the proscribed minimum distance
