MDF Roads and Rivers released!
Started by Leon, 24 February 2025, 03:54:13 PM
We've got a really useful release for you next with a load of handy shapes for making roads and rivers!  These are available in a huge variety of shapes and sizes, with straights, curves, junctions and more in widths from 20mm up to 75mm.
Despite these being simple MDF shapes, the possibilities are almost endless.  A quick coat of grey and some white lines gives you a road, a coat of brown and some static grass gives a country lane, and painting them blue/green/brown makes for an easy river (depending on your view of water colours...)  You could even paint both sides and flip them over depending on what you need for each game.
And the best bit is the value for money.  These are priced very competitively so you could build a full 6ft river or road for less than £5 if you wanted!
And to show what can be done with these, our friend Dave Docherty took some of the test pieces and used them for a 15mm winter table he's been building.  We've included some images below but you can see the full process on his blog here: https://onemanhisbrushes.blogspot.com/2025/02/terrain-stream-for-winter-table.html
Roads and Rivers - https://www.pendraken.co.uk/roads-rivers
Roads
ROA-ST-20    Straight section, 20x150mm    £0.30
ROA-ST-25    Straight section, 25x200mm    £0.50
ROA-ST-30    Straight section, 30x250mm    £0.75
ROA-ST-40    Straight section, 40x300mm    £1.25
ROA-ST-50    Straight section, 50x300mm    £1.75
ROA-ST-75    Straight section, 75x300mm    £2.50
ROA-45-20    45° curve, 20mm width    £0.30
ROA-45-25    45° curve, 25mm width    £0.50
ROA-45-30    45° curve, 30mm width    £0.75
ROA-45-40    45° curve, 40mm width    £1.25
ROA-45-50    45° curve, 50mm width    £1.75
ROA-45-75    45° curve, 75mm width    £2.50
ROA-90-20    90° corner, 20mm width    £0.30
ROA-90-25    90° corner, 25mm width    £0.50
ROA-90-30    90° corner, 30mm width    £0.75
ROA-90-40    90° corner, 40mm width    £1.25
ROA-90-50    90° corner, 50mm width    £1.75
ROA-90-75    90° corner, 75mm width    £2.50
ROA-TJ-20    T-junction, 20x150mm    £0.30
ROA-TJ-25    T-junction, 25x200mm    £0.50
ROA-TJ-30    T-junction, 30x250mm    £0.75
ROA-TJ-40    T-junction, 40x300mm    £1.25
ROA-TJ-50    T-junction, 50x300mm    £1.75
ROA-TJ-75    T-junction, 75x300mm    £2.50
ROA-XR-20    Crossroad, 20x150mm    £0.30
ROA-XR-25    Crossroad, 25x200mm    £0.50
ROA-XR-30    Crossroad, 30x250mm    £0.75
ROA-XR-40    Crossroad, 40x300mm    £1.25
ROA-XR-50    Crossroad, 50x300mm    £1.75
ROA-XR-75    Crossroad, 75x300mm    £2.50
ROA-YJ-20    Y-junction, 20x150mm    £0.30
ROA-YJ-25    Y-junction, 25x200mm    £0.50
ROA-YJ-30    Y-junction, 30x250mm    £0.75
ROA-YJ-40    Y-junction, 40x300mm    £1.25
ROA-YJ-50    Y-junction, 50x300mm    £1.75
ROA-YJ-75    Y-junction, 75x300mm    £2.50
Rivers
RIV-ST-20    Straight section, 20x150mm    £0.30
RIV-ST-25    Straight section, 25x200mm    £0.50
RIV-ST-30    Straight section, 30x250mm    £0.75
RIV-ST-40    Straight section, 40x300mm    £1.25
RIV-ST-50    Straight section, 50x300mm    £1.75
RIV-ST-75    Straight section, 75x300mm    £2.50
RIV-45-20    45° curve, 20mm width    £0.30
RIV-45-25    45° curve, 25mm width    £0.50
RIV-45-30    45° curve, 30mm width    £0.75
RIV-45-40    45° curve, 40mm width    £1.25
RIV-45-50    45° curve, 50mm width    £1.75
RIV-45-75    45° curve, 75mm width    £2.50
RIV-90-20    90° corner, 20mm width    £0.30
RIV-90-25    90° corner, 25mm width    £0.50
RIV-90-30    90° corner, 30mm width    £0.75
RIV-90-40    90° corner, 40mm width    £1.25
RIV-90-50    90° corner, 50mm width    £1.75
RIV-90-75    90° corner, 75mm width    £2.50
RIV-YJ-20    Y-junction, 20x150mm    £0.30
RIV-YJ-25    Y-junction, 25x200mm    £0.50
RIV-YJ-30    Y-junction, 30x250mm    £0.75
RIV-YJ-40    Y-junction, 40x300mm    £1.25
RIV-YJ-50    Y-junction, 50x300mm    £1.75
RIV-YJ-75    Y-junction, 75x300mm    £2.50
RIV-WD-20    Widening section, 20-25x150mm    £0.30
RIV-WD-25    Widening section, 25-30x200mm    £0.50
RIV-WD-30    Widening section, 30-40x250mm    £0.75
RIV-WD-40    Widening section, 40-50x300mm    £1.25
RIV-WD-50    Widening section, 50-75x300mm    £1.75
RIV-WD-75    Widening section, 75-100x300mm    £2.50
RIV-SP-20    Straight with pool, 20-40x150mm    £0.30
RIV-SP-25    Straight with pool, 25-50x200mm    £0.50
RIV-SP-30    Straight with pool, 30-60x250mm    £0.75
RIV-SP-40    Straight with pool, 40-80x300mm    £1.25
RIV-SP-50    Straight with pool, 50-100x300mm    £1.75
RIV-SP-75    Straight with pool, 75-150x300mm    £2.50
I'm pretty sorted for roads, but those river sections will be very useful :) !
Yes, the river sections could be useful (and there is no reason the roads, can't be used as straighter river sections).
Damn, I can't decide what width to get!
You've got my attention.
One other idea (knowing how terrible I would be at painting road markings).
Would it be possible to etch the road markings, as a painting guide.
Any laser etching is obviously darker, an outline to guide the "league of clumsy painters" * might be a major selling point.
* The first rule of League of Clumsy Painters: Never reveal your membership of LCP. ;-)
QuoteDamn, I can't decide what width to get!
Just over twice as wide as a vehicle...
Corso
#7
I was only wondering the other day how I could model a small river for my current project
2024 Painting Competition - 1 x Runner-Up!
Quote from: steve_holmes_11 on 24 February 2025, 06:53:32 PMJust over twice as wide as a vehicle...
10mm Napoleonic, 6mm modern or 28mm 7TV?
I've been making my own tracks and roads out of sandpaper glued onto mounting board, have found 4cm wide roads are suitable for 10mm and 15mm and just about getawayable with for 20mm and as token gestures for 28mm games. As our 28mm games are 19th century, the latter isn't too much of a problem, and certainly not worth the extra effort of making wider roads(unless we ended up playing only 28mm games)
It's a thought, but for Napoleonic, Sunjester and I have been using Blucher 'Grand Scale' With my basing 4cm is a stand width of 1000 men, so a little big...  :'(   ;D
WW2 is 10mm, and a 1:1 ground/figure scale for my own rules, so 4cm would be 6 meters; A little wide (6m or 20 feet to the ancients among you). Ok for a modern town small road, and probably doable. Tempted to get the rivers as I assume they will be a bit wiggly - better for country lanes.
Ooo - While I think of it - Leon, have you thought about doing 'reduction join bits' (technical term) so you can join different widths together? They wouldn't need to be very long, just enough to join, say, 40 to 30 widths.
Quote from: Last Hussar on 25 February 2025, 01:29:44 PMOoo - While I think of it - Leon, have you thought about doing 'reduction join bits' (technical term) so you can join different widths together? They wouldn't need to be very long, just enough to join, say, 40 to 30 widths.
Now that's a good idea, especially for the rivers.
Of course it's a good idea, I had it!  :D
Quote from: sultanbev on 25 February 2025, 01:38:36 PMNow that's a good idea, especially for the rivers.
Quote from: Last Hussar on 25 February 2025, 02:15:26 PMOf course it's a good idea, I had it!  :D
I'm afraid we beat you to it! The good thing about a Widening section is, if you turn it around it becomes a 'reduction join' instead...  ;)
See if this was GW, they'd list both.
Under different prices...
Quote from: Last Hussar on 25 February 2025, 04:04:39 PMSee if this was GW, they'd list both.
Now there's an idea...!  :D
It's got to be against trading laws
I bet you not! They only make a law if it's been a problem, and I'm not sure what 'parallelograms of mdf' would be swept up in!
Side note - if you read about a 'stupid law' its quite probable there has been a problem in the past, based on 'socially acceptable' at the time, and Parliament (or national equivalent) has had to go 'Really, you need to be told this?'  For instance, there is a reason why the US has laws about posting children in the Federal Mail...
O Dinas Powys
Crazy thought, but what about doing the rivers in 32mm*, include a cruciform piece, and some roughly oblong "pools" and marketing them as a cave system to dovetail with The Dungeon...  :-\
* and/or full width of the dungeon pieces...
