Christmas campaign 2024
Started by fsn, 26 December 2024, 02:34:56 PM
A cool second half to the game - I did think the Brunswick early deployment would help them, but they didn't seem able to get to grips with the few early Austrians. Then it just seemed that the Austrian steam roller arrived - all 500 of them  :o
I assume you are using the 'put everything on the table' method of army selection? So those that have been favoured in the painting and buying stages, get more numbers on the table?
Quote from: fred. on 02 January 2025, 07:35:52 PMA cool second half to the game - I did think the Brunswick early deployment would help them, but they didn't seem able to get to grips with the few early Austrians. Then it just seemed that the Austrian steam roller arrived - all 500 of them  :o
You're quite right. The Grenzers were not going to do much on their own, and the key was the Austrian light cavalry arriving which hampered the movement of Brunswick line brigade. Even I was impressed and/or depressed (depending on which side of the table I was) when I saw the massed Austrian infantry!
Quote from: fred. on 02 January 2025, 07:35:52 PMI assume you are using the 'put everything on the table' method of army selection? So those that have been favoured in the painting and buying stages, get more numbers on the table?
I do try and have armies of about the same strength, but keep the "flavour" of the original. The Austrians are cavalry heavy, and the Russians have lots of artillery. The Swedes fielded 780 infantry, 120 cavalry and 3 batteries; the Danes 795, 100 and 4. I base each one on a named order of battle. The Swedes from Leipzig, the Danes from Sehested.
The Brunswick Corps (from 1815) suffers from being historically so small- only 512 infantry, 90 cavalry and 2 batteries.
Quarter Final 3 Wurttemberg vs Great Britain
I've trimmed down the British here to have the same sort of size as the Wurttembergers - 3 infantry and 2 cavalry brigades. The difference will be that the British have a Corps Commander (Hill) as well as two divisional commanders (Clinton and Coleville) which should give them some freedom from Lady Die.
Move 1 von Koch's Wurttenberg brigade came on by Ghost farm. The KGL brigade of du Plat march on at the opposite corner.
The 4 battalions of the KGL start
Move 2 du Plat seems indifferent to the advancing Wurttembergers and carries on with his country walk. This seems to annoy von Koch, who decides to attack.
The 4th & 5th Wurttemberg regiments make for the KGL
Move 3 von Koch chivvies his units into attack column, whilst the KGL move on serenely, their support artillery making it onto the table.
Elsewehere, mid-table von Hugel with the 1st and 2nd Regiments move on the road. At the other end of the road, the British heavy cavalry brigade of Ponsonby sight the Wurttembergers and immediately decide to attack.  (Who'd have thunk?)
Move 4
von Hugel's brigade has the road blocked, so the light brigade of von Brusselle can't come on the table yet. However, the Divisional commander von Franquemont gallops past the stalled bridade to give von Hugel some sage advice.
A Wurttemberg light cavalry brigade also appears - wrong side of the bridge.
For the British, division commander Clinton arrive by the church, leading the light brigade of Adam.
British light infantry and Rifles of Adam's brigade
As the 1st Dragoons form into line, the 2nd British Dragoons appear behind them. Ponsonby chivvies them into line.
Move 5
At Ghost Farm, the Wurttemberg columns move solemnly to attack. The 1st KGL Battalion turns smartly to line and begins steady volley fire.  Meanwhile, the remaining KGL battalions continue as if on a Sunday parade at Hyde Park, du Plat waving them on whist nonchalantly smoking a cigar.
Daddy Hill leads 4th Division Commander Colville and Mitchell's brigade between Adam's brigade and the cavalry.
The Wurttemberg ChL, obviously having more gumption/bravery/stupidity than the Austrian Cuirassiers from the last battle, begin to cross the bridge. The British 1D, pausing briefly, see a new, closer, weaker target than and infantry brigade, and begin to roll down on the disorganised Wwurtembergers.
End of Move 5
We seem to have three balanced, yet separate actions. By the bridge, the plucky Wurttemberg light cavalry will have a tough fight against the British heavies.
In the middle, the bulk of the British infantry will face off against the bulk of the Wurttemberg infantry.
By Ghost Farm, the KGL seem to be very unconcerned by the approaching Wurttemberg brigade.
Still to come on are a British light cavalry brigade  (Vandeleur's Light Dragoons), the 2nd Wurttemberg light cavalry brigade (which is stuck behind the first) and the Wurttemberg light infantry (which is patiently waiting for von Hugel's troops to get out the way.)
To be continued ...
*Grump*
I've had a bad few days. I've lost my notes from the Brits vs Wurttemberg game, and the photos I took of the end of it and the Bavaria / Poland game have disappeared into the ether. Bavaria won.
The rest of the Brits vs Wurttemberg will not have the move by move description, I'll do it in the three separate areas.
In the south, by Ghost Farm, the KGL brigade performed perfectly. The 1st Bttn delivered controlled volleys into the advancing columns, as the 2nd Bttn moved perfectly to flank the Wurttemberg columns, each company coming into line and pouring fire as they could. Caught by foire from 2 directions, the first Wurttemberg battalion checked. The second stumbled. The KGL charged and the two leading Wurttemberg  units broke and ran; causing the following battalions to become disordered and easy prey for the advancing KGL.
In the centre, the British heavy cavalry brigade continued in "charging at everything". The Scots Greys assaulted the Wurttemberg square, whilst the following 6th Dragoons spotted an undeployed artillery battery, and hurled themselves at it. Although the Scots Greys were eventually thrown back by the square, the British Light Dragoon brigade had deployed to take over the assault. Meanwhile, the 6th, having gone behind the square were in a position to threaten the rear of the main body of the Wurttembergers.
Meanwhile, the British light infantry brigade deployed skirmishers and then thickened up into line, causing the von Hugels's second regiment (ironically the 2nd) some casualties and consternation. Von Hugel's men started taking fire from two battalions of the 95th Rifles, and von Hugel fell prey to one of these sharpshooters.
At the bridge, the British 1st Dragoons threw over the Wurttemberg Cheveau Legers, but followed them over the bridge. The second Wurttemberg regiment had deployed and counter charged, throwing the British back in disorder. Fortunately, the British light dragoons were in a position to support and the bridge became a stalemate.
The Wurttemberg right had been destroyed by the KGL. The left was in stalemate with the British cavalry over the bridge, and the centre was being attacked by both cavalry and infantry, with a regiment of British heavy cavalry reforming in the Wurttemberg rear.
Worse still for von Franquemont, British artillery was close to being deployed against the juicy target of the infantry square. He clapped his spurs to his horse and led his battered troops off the field.
That's the last of the quarter finals. The semi finals are set as Sweden vs Austria and Britain vs Bavaria.
I am fed up with that *%"*&ing bridge, so I have decided to do a new map for the semis - with no *%"*&ing bridges.
Is that a technical term for the bridge, or the bridge near the village of...
Quote from: Duke Speedy of Leighton on 18 January 2025, 07:22:50 PMIs that a technical term for the bridge, or the bridge near the village of...
I think it is something similar to a swinging bridge.
I believe the correct term (since Jan 1st 2021) is "that Fugging bridge". The inhabitants having grown tired of having their signs stolen and the general merriment of the English speaking world at their village's previous name.  ;)  :)  :)
Another great looking game :-bd  =D>  :-bd  =D>
Quote...
In the south, by Ghost Farm, the KGL brigade performed perfectly...
As is to be expected
I hope this week improves and fighting where there isn't a bridge seems eminently sensible
Last weekend I fought the two semi finals - no photos unfortunately - but there is a new table which has a grand total of zero bridges.  My device has been replaced, and I'm fighting the final this weekend.
Semi-Final 1: Sweden vs Austria
The Swedes stormed onto the table, the three infantry and one cavalry brigade entering the table at different but close points around the middle of the left side of the table (green 12-16). The infantry quickly took the high ground in the upper part of the table, and were able to form up in an almost leisurely fashion whist waiting for the Austrians. Meanwhile, the cavalry trotted to the southern hill to take control of that as well.
The Austrians (bless 'em) had only their light infantry appear on move 1,  at yellow 18, so they had to spend a bit of time working their way through the trees. Fortunately for the brigade, they also threw a "1", which is a "do not do anything" command, so they took off their packs and enjoyed the sunshine for a while.
By the time the Austrian infantry began to meander on, the Swedes were set to take them under artillery fire, and the Swedish cavalry, finding the Austrian light infantry apparently disinclined to move, came down like a wolf on the fold of the bemused Austrians and routed the first brigade.
Victory to the Swedes.
Semi Final 2: Britain vs Bavaria
The British army, if fully deployed would be nearly twice as large as the Bavarian, so I trimmed it to be about the same size.
The British infantry made it on fairly early, on Green 2 to Green 4, so quickly took the southern high ground. The two heavy cavalry brigades also were on the table by move 3, coming in a bit further north, either side of the buildings at Green 12.
Early signs of the Bavarians were the light cavalry at yellow 7 and yellow 4. As the cavalry made its way south, the infantry dripped in. The first brigade coming on move 4 at yellow 15 - right under the muskets of the prepared British infantry. Well, that didn't go well for the Cornflower Blues.
Meanwhile, the middle of the table saw a clash of cavalry. Despite being outnumbered, Somerset's Household Cavalry threw themselves at the first Bavarian brigade, and put it to flight, then were counter charged by the second Bavarian brigade and only saved by the timely intervention of Ponsonby's heavies.
By now, the British Rocket Troop had made its way through the woods at Green 8, and into a position to begin a lethal fireworks display (mostly) against the Bavarian infantry, which was enough to discourage the Bavarian National Infantry (Militia) who suddenly remembered they had business elsewhere.
Victory to the British.
The Final will be Sweden vs Britain
Hmmm. Both of these battles were dictated by the victor having plenty time to get on the table in a reasonably concentrated way, whilst the loser was late, and certainly for the Bavarians thrown in piecemeal.
I am contemplating having all troops on the table for the final.
Perhaps allow each army to deploy half their troops at the start of the game, then roll for the rest? Avoids the no-one has turned up issue, but still gives some variability?
Fred's suggestion seems eminently sensible :)
