Suppression & Falling Back
Started by Dice Dad, 01 June 2022, 07:40:35 PM
Dice Dad
Hi, first post yay!
I have a question about Suppression and Falling Back. If a unit is not destroyed and needs to resolve remaining hits can it become Suppressed and Fall Back in the same turn?
I.e. I have two unsaved hits. I become Suppressed with the first. If I fail the second do I then also Fall Back?
Welcome to the forum Dice Dad :-h
or may we call you Dice ;)
I'm sure someone who plays the rules will be along shortly to answer your question
Genom
I'm pretty sure it's diced for within the current attack. So you roll all hits to check for suppression within the current attack. If the unit takes further hits from a different attack then fallback can happen against already suppressed units.
Dice Dad
Thanks for the response. That was how I interpreted it.
QuoteHi, first post yay!
> if both hits occur from the same round of firing (& that is why it is important that when shooting at a target all shooting at that target is nominated at the same time) then the answer is No. You roll all your Save dice at once and then all your Suppression dice at once - on that roll it doesn't matter how many suppressions you get, you only count suppressed the once.
However, if in the next commanded order, your opponent targets that same (already) suppressed unit and you get more suppression, then the fall-back mechanism comes into play.
Again, it is important to stress that the target unit must be hit all at once by all on-table fire at the same time in relation to a specific Command order. So your opponent cannot fire one unit at a time at the same target and if it is destroyed, then divert the remaining units under his command to fire at a different target. Target nomination must take place at the start of the order ahead of the command roll being made.
Hopefully that makes sense.
Answer above on-line
Dice Dad
That does make sense, thank you.
