wood glue debonding tips?
Started by collegialhoagie, 07 April 2022, 07:26:41 AM
Quote from: mmcv on 07 April 2022, 03:30:03 PMI am tempted to try it, I tend to just use blu/white tac but can end up peeling a bit of paint away from the base when removing at times.
I use Blu-Tac all the time and yes, it will obscure some parts of the base when painted.
I finish the figure and also the base as far as possible. I then remove the figure from the Blu-Tac and touch up the parts of the base that were missed before basing the figure.
QuoteI use Blu-Tac all the time and yes, it will obscure some parts of the base when painted.
Yeah I'm much the same, it's usually not a big deal as the bases get touched up with a mix of paint and pva for the basing material anyway, but do get the odd time where I missed a spot and some bare metal shows through. It's only a tiny speck, but always catches the eye!
My main dislike of using glue for the sticks is having to wait for them to dry before painting. I tend to prep a few sticks then prime them and leave that to dry. Adding an extra drying step between those means I'd have to do bigger batches which can get a bit tiresome.
I use double sided sticky tape for figures on painting sticks
Works great. No waiting to dry, no issue removing the figures. The hardest bit is peeling the backing off - and that's not really hard.
I find double sided tape mildly annoying.  :-\
I solve the glue problem by having several batches on the go at once. Usually 1 in paint, 1 in primer and 1 in "prep".
Means I know what I'm painting next, 'cos it's all perfectly planned.  :^o
Works for me!
I also use double sided sticky tape, hasn't annoyed me yet ;)
Use blutac for 6mm vehicles (the infantry I glue direct to a base) For all else uhu, no problem getting them off. Occasionally clean the residue of either off.
