MDF bases storage solutions?
Started by mmcv, 26 March 2022, 08:39:47 PM
What are you all using to store your MDF bases?
Thus far I've been mostly keeping them in their bags and piling into a small plastic box but there has to be a better way than rummaging around in that every time, especially when they keep spilling out of the bags!
Any good solutions?
Mine are in A4 filing trays. I empty smaller bags into larger bags (as received in bulk order) and keep them in size order. So I know that this tray has 10x30, then 20x30, 30x30 ... to 60x30 - bigger ones at the back.
A second drawer has circular and individual bases.
No problems.  :D
My solution is simple, anyone can do the same.
I keep MDF bases in zip lock bags, they often come in one. I mark their dimensions on the bag with a large sharpie. I make sure the bags are closed properly.
I must have several hundred bases in storage as I always buy twice as many as I think I need therefore always having the right ones to hand.
Simple.
Mine are in a desk drawer.
Big clear bag for each of rectangular, circular and plastic.
Then within in the smaller bags they come in. For the two main sizes I use (30 and 40mm squares) I have separate bulk bags of them.
It can take a bit of rummaging but not usually too much.
Ziplock bags (I like to rummage).
Order of heap, except the 40x20 ones. The circular ones are separate from the squares and rectangles but the plastic and MDF are all mixed together.
Certainly the big bag bulk buys are much easier to keep organised than the mix of little ones. Sounds like baggies are still the main way. Might try and rummage for some bigger bags and use them to organise the smaller bags together.
jambo1
You may not want to follow my advice, mine are in every drawer in the house and in no particular order, loads lying on my painting station and in boxes stashed all over the house! :)
Mine wre in one of those storage boxes used for screws etc. with thw sizes labled on each section.
The extras are in an A$ box file in my Den
QuoteMine wre in one of those storage boxes used for screws etc. with thw sizes labled on each section.
I was thinking that as I use something like that for basing material, though the one I have is too small for much by way of bases, would need a fairly large one.
For the moment I've sorted through the box, returned the bases to their bags, labelled them properly and piled them up in sections for different shapes. Will just need to get some bigger bags to store those in.
QuoteFar far to organised !!
You say that but this is because my hobby area has become so cluttered I haven't space to paint or game so working my way through sorting it a bit to give myself some room.
Though I did get sidetracked starting to build a model house with some MDF bases and adding some coffee stirrer cladding. I have been stymied though by being unable to find my pile of card and suchlike for the roof.
Alas the tidy must continue tomorrow.
A small, yellow, filing basket...
I use the plastic cases from Deagostini 1/72 tank models, placed upside down and put together on a shelf in the cellar. Each box contains one base size. Empty margerine cartons would work as well, once you've eaten enough margerine.....
Cardboard box next to my desk, filled with innumerable baggies of different sized bases, where hopefully the little stickers have stayed stuck on...
Or not, leading to much... that's a 30*20... no, 25*20... no, it's a 30*15... wait...
