Unread posts/ Updated topics not working
Started by Orcs, 14 March 2022, 08:51:55 PM
Hi,
When I press either the unread posts or the Updated Topics I get no listings of threads at all
Quote from: Lord Kermit of Birkenhead on 15 March 2022, 10:08:10 AMMind you still no formating or emojis
Mentioning it every other post won't make them appear any quicker...!
Leon - if you're in contact with your web guy on this I'm 90% sure that the issue is that the script tag in the head for the sceditor is wrong, it's using
   <script src="http://www.pendrakenforum.co.uk/Themes/default/scripts/jquery.sceditor.bbcode.min.js?smf21rc4_1638898865"></script>;
When it should be using https:
   <script src="https://www.pendrakenforum.co.uk/Themes/default/scripts/jquery.sceditor.bbcode.min.js?smf21rc4_1638898865"></script>;
Quote from: Leon on 15 March 2022, 12:16:46 PMMentioning it every other post won't make them appear any quicker...!
WHY NOT :-}
DecemDave
Are we there yet?
Quote from: mmcv on 15 March 2022, 12:26:12 PMLeon - if you're in contact with your web guy on this I'm 90% sure that the issue is that the script tag in the head for the sceditor is wrong,
Thanks for the info, the https/http setting was changed during the painting competition as some browsers weren't displaying hosted pictures properly, so we had to adjust that to get them to work.  That issue seems to be a wider fault within the SMF software as it happens on other forums as well.
Making that tweak has then knocked out various other settings for some reason, but simply reverting back to the previous settings hasn't seemed to work.  I'll check in with Stewart and see how he's getting on.
Techno 3
At least the drop down menu, I use to log out, seems to be working...more than not, at the mo'.
Seems to depend on the last thing I've looked at.
No problems with unread posts here.
I'll try using Doppelganger a bit later. :-)
Interesting.....I could use Modify to correct a spelygn mistake..But not quick edit.
I'll do this later
DecemDave
Not wishing to tempt fate, but it all looks good and back to normal :) .
Quote from: Steve J on 16 March 2022, 05:34:38 PMNot wishing to tempt fate, but it all looks good and back to normal :) .
Well whatever normal is for this bunch of Misfits*, Miscreants* and Weirdos* (Other derogative names are available :)
* Please delete any two that do not apply as applicable. (No one on this forum will believe anyone here is able to delete 3)
