Please leave this thread alone.
Started by Phil2, 22 February 2022, 07:42:48 AM
Phil2
Feel free to look....But please don't post anything.
My current doppelganger may appear....But that's all I'd like to see here.
Doing some testing for Sir.
Thanks - Phil.
Phil2
I can't see a delete button..even coming back after 2 minutes. :-\
Phil2
Well......The difference between looking at the forum and the tablet is something.
Using the tablet....It recognizes me as Phil2.....But I don't have the facility of marking 'all messages as read.'....I do with the PC.
Using my other 'Nom de plume'.....It doesn't recognize my password and says it will send an email to reset my password.....It frigging well doesn't. X_X .....Maybe be it will in a few hours.
Using the PC....Can get into both accounts....without messing around.
Now (next) for a  one line message from Phil2....and see if I've got a delete button, to get rid of it.
Phil2
I want to delete this.....But can I ?
No.....I could edit it....but there's no delete button...that's after 3 ? minutes.
Phil2
Well...I've edited it...But I can't delete it.
Phil2
Hey, ho!!.....I'll start again completely from scratch.
Leon  :-* ....If you would be so kind....delete both Phil2...and my alter ego....and I'll start from scratch with both of them.
Cheers - Phil. :)
Techno 3
Still well unimpressed.
On the tablet (now)....took far too long to mark all messages as 'read'.
I'll do this later
Techno 3
Still no obvious delete button...even after 2 minutes.
I'll do this later
I'm not sure how it appears on a tablet but the Delete button should be to the bottom right of a post where it says 'More', and then when you click/hover it shows 'Remove'.  Again though, I'm not sure how that looks on different devices and also how long it remains visible for on a regular account.
Techno 3
28 February 2022, 07:18:20 AM #9 Last Edit: 28 February 2022, 07:28:07 AM by Techno 3 Reason: Checking for delete button.
First go)... I'll give that a whirl, Leon.
First 'Modify') Hmmmm.....Unless I'm missing it....I can only see "Report to Moderator" or "Modify."
I'll have another look after I've saved this.
Second 'Modify') No.....Unless my eyes are playing really silly sods, I can't see 'delete'
Third....No clicking on 'More'.....Just gives the options mentioned in the 'First 'Modify' .
I'll do this later
Been waiting to.long, but no, shan't!
Techno 3
I'm going to go into one of the threads that have you marked as Moderator, Will....Post something, and then see if you can delete it...well.... basically find a delete button.
Your Moderator 'flag' doesn't seem to be showing now..(It was before)..Though I'm sure I've seen you marked as moderator on certain boards.
My Mod functions are switched off to see how it behaves.
So far, so good.....I haven't seen any spurious posts, from the year dot, marked as unread.
I still can't see any delete button, even after just 2 minutes. :-\
I'll do this later
Techno 3
So what happens if I modify something, to give a completely blank post.
See what occurs with the next post.
I'll do this later
Techno 3
Nah.....that doesn't work.....blanked the message but then I get ..
The message has the following error or errors that must be corrected before continuing:
The message body was left empty.
I'll do this later
Quote from: Techno 3 on 01 March 2022, 07:51:26 AMNah.....that doesn't work.....blanked the message but then I get ..
That's quite a standard thing, the message box can't be left completely empty so usually folks would leave a comma or full stop in there as a space filler.  I'd then spot that and delete the post.
