Newfangled photo hosting test
Started by Shapur II, 07 February 2022, 09:31:42 PM
Shapur II
Test image from flickr
Nope. That did not work
Active Projects
10mm 1809 Austrians, 1809 French,1809 Bavarians, Normans, Arabs
Rules
HFG, Marshal's Baton, Hail Caesar, Black Powder
The image tags expect a .jpg. If you use the BBcode on flckr it will give you the actual location of your jpg Which you can cut out of the BBcode string. Place it between the image tags. There is undoubtedly easier ways to do this. What I did is pretty klugey.
The .jpg for the above looks like this:
\https://live.staticflickr.com/65535/51866500594_78c8dbc68f_k.jpg
I think some use flckr here and will likely give you a better way😀
Oops! Forgot to size the pic. Sorry
I use Flickr, I copy the BBcode and paste it in directly. This should show the image and allow people to click on it to go to Flickr.
I remove the second part of the BBcode
[url=https://flic.kr/p/2n2x2fW]IMG_1611[/url] by [url=https://www.flickr.com/photos/151469192@N07/]Paul Reynolds[/url], on Flickr
This gives a line of text such as IMG_1611 by Paul Reynolds, on Flickr
You can add a width=900 in the img tag to control the size of the image
[img width=900]https://live.staticflickr.com/65535/51866500594_78c8dbc68f_k.jpg[/img]
Shapur II
Many thanks Gentlemen,
[/url]IMG_0581 by Stu Gibson, on Flickr
We have progress!
French Napoleonic Cuirassier advancing in Belgium
Stu
Active Projects
Rules
Cuirassier but don't look very Napoleonic ;D
