Simple Home Remedies
Started by Orcs, 24 November 2021, 09:03:43 AM
I'm sure some of you make use of these helpful home remedies.
1. If you are choking on an ice cube simply pour a cup of boiling water down your throat. The blockage will instantly remove itself.
2. Avoid cutting yourself slicing vegetables by getting someone else to hold while you chop.
3. Avoid arguments with the Mrs. about lifting the toilet seat by using the sink.
4. For high blood pressure sufferers: simply cut yourself and bleed for a few minutes, thus reducing the pressure in your veins. Remember to use a timer.
5. A mouse trap, placed on top of your alarm clock, will prevent you from rolling over and going back to sleep after you hit the snooze button.
6. If you have a bad cough, take a large dose of laxatives, then you will be afraid to cough.
7. You only need two tools in life - WD40 and Duct Tape. If it doesn't  move and should, use the WD40. If it shouldn't move and does, use the duct
tape.
8. Remember: Everyone seems normal until you get to know them.
Thought for the day: SOME PEOPLE ARE LIKE SLINKIES. THEY'RE NOT REALLY GOOD FOR ANYTHING, BUT THEY BRING A SMILE TO YOUR FACE WHEN YOU PUSH THEM DOWN THE STAIRS.
Quote3. Avoid arguments with the Mrs. about lifting the toilet seat by using the sink.
LOL! Thanks, brightened up my day has that.
Cheers.
Think that deserves a coat chewing......
There's some great ones in there ;D .
Quote from: sunjester on 24 November 2021, 01:21:35 PMQuiet day at work Mark?  ;D
And Boring. Had to go in office so can't even paint.
Number 7 has got me through 75 years.
Sleep with clean hands ...
Techno II
