Stonehenge Blocks Solution?
Started by Westmarcher, 06 July 2021, 09:17:28 AM
OK .... now I'm even more confused!
Quote from: Ithoriel on 07 July 2021, 12:38:01 PM
I'm with the group who think the easiest way to get the stones to Stonehenge et al from their source is by sea. Cut wooden rollers, heave blocks onto the rollers (or onto a frame on the rollers), roll to the nearest bank of a sizeable river or the nearest beach, turn the rollers into a raft, float stone as near as possible to Stonehenge site, turn raft back into rollers, position stone, rinse and repeat.
So, the quarry in West Wales, down to the coast, onto a raft and across the Severn Sea to Somerset, which was quite a bit wetter than it is now, I believe, so yes, I'd believe a raft/boat could possibly get quite close.
The scary bit would be crossing the Severn estuary - might be more sensible to stick to the coast along South Wales, then across somewhere further up river than the bridges are now. Strong tides though.
I suspect the recreators did something wrong, in some way - anyone got a good link to their methodology?
Like Ithoriel says I can't imagine their boat-tech was substantially worse than e.g. the Egyptians but...
That's a nice boat!
That should do the job :)
But it does mention the one 70' beneath Pembroke  Dock!!!
We were there the other week, didn't spot it.
No bruised, broken and battered Boy Sprouts being shouted at by tweedy professors as their makeshift rafts sink, either.
I knew it was all a conspiracy...
Quote from: toxicpixie on 08 July 2021, 03:31:17 PM
To you Pixie everything is a conspracy
Techno II
09 July 2021, 06:11:48 AM #28 Last Edit: 09 July 2021, 06:40:40 AM by Techno II
What about the theory that the pyramids were constructed of 'cement' blocks that were formed from individual moulds, in situ ?
This is why they fit so perfectly together.....(and why you can't even slip a piece of paper between the blocks.......apparently. =))
Anyone else seen that one ?
Cheers - Phil. :)
I believe that's what they say about Inca masonry.
Quote from: Lord Kermit of Birkenhead on 09 July 2021, 05:12:50 AM
You would say that, you're part of it. Them. I bet YOU built Stonehenge just to mess with us...
Heedless Horseman
FIVE large'ish Stone blocks just FELL OUT of the front of the house last Summer!  :'( :'( :'( A 'course' above a window on a 60s bungalow. Apparently had not bee 'tied in'.
The 'upside' was that,HAVING to get things repaired, it led to a whole lot of other work actually getting done!   ;D :)
The Pyramids and Inca bulds... amazing what a 'dedicated, and enthusiastic team' can achieve... when they 'HAVE'  to...  :o  ;)
Quote from: Techno II on 09 July 2021, 06:11:48 AM
Cheers - Phil. :)
Apart from the fact that the blocks in the pyramids aren't made of cement I see nothing wrong with this theory.
Besides, everyone* knows that the aliens laser cut the blocks for the Egyptians.
Otherwise the Egyptians couldn't have built them to the required tolerances to let the aliens land their spaceships on them. :)
*For a certain value of everyone
DecemDave
Quote from: Ithoriel on 09 July 2021, 12:15:42 PM
How can the moderators permit the spreading of such nonsense on an erudite forum like what this is?
The pyramids were clearly built by time travellers to provide a stable landmark they could return from.
Time travellers? Pah! They're plug-in charging points for UFO's, everyone* knows that. :)
*see above :D
Heedless Horseman
Quote from: Ithoriel on 09 July 2021, 01:14:56 PM
*see above :D
Now, there's a thought? Have any of the 'ancient aliens' theorists about Pyramids / Henges/ Nazca... etc. ever 'snapped' UFOs actually visiting the sites?
You used to see country stores / garages, with LONG defunct petrol pumps!
Maybe 'Geo Magnetic energy' just aint't 'Green' anymore?  :o ;)
Quote from: Heedless Horseman on 09 July 2021, 01:43:33 PM
No - they only come very late at night and have high end stealth gear
Heedless Horseman
Quote from: Lord Kermit of Birkenhead on 09 July 2021, 03:36:11 PM
So... Galactic 'Teens' then...  ;D
Heedless Horseman
14 July 2021, 04:33:31 PM #38 Last Edit: 14 July 2021, 04:36:26 PM by Heedless Horseman
Just watched a recorded BBC Doc: 'Stonehenge... The Lost Circle, Revealed'. Suitably hirsute archaeologist tracing origin of the first Stonehenge circle of 'Bluestones'. Lab mineral analysis appears to trace back to two nearby outcrops in Wales. Some unfinished blocks stiil there? Prob was, quarried about 3 centuries before Stonehenge... so erected on another site...and recycled?
He found the remains of a Circle, close by... with evidence of stone removal... and corresponding in dimensions to Bluestone circle at Stonehenge. 'Possible' folklore tie to the 'Merlin Myth' in later tales? Certainly 'Seems' to fit the bill!
Transportation. He was sceptical about the 'coastal' method. Fabricated a 'sledge' and recruited gang of schoolkids to drag a slab about the size of one of the smaller stones 70 yds... successfully.
So, no real 'need' for 'advanced' techniques of trackways, bearings, 'walkers'...
Methinks... possible but 140 miles with detours, bridging, etc.? Well, 'maybe'! Could have been more than one method trialled?
Why? Unknown. But, remember... in 1870s /80s, 'Cleopatras's Needle(s)' Obelisks transported from Egypt to London and New York! People DO do 'strange' things... LOL!
The TV prog certainly plausible... worth the watch if it comes round.
Of course, these were the 'man-size' Bluestones... not the enormous, but 'locally' sourced Sarsens. THEY would have been 'Real B*****s' to shift!
(But, just maybe... someone wanted to replace their patio with Decking... and someone, seeing the Skip, said: " 'Ere! If you don't want those bits, can I grab a few?" )
 ;D ;D ;D
Thanks for flagging up the programme. Just watched it on the Beeb website and an interesting watch it was too.
