Gun over penetration needed to kill a tank.
Started by Last Hussar, 11 February 2021, 08:58:36 PM
I must not buy any more 10mm until I've painted what I've got.
:D
Quote from: sultanbev on 02 June 2021, 07:22:42 PM
I do not understand this statement?
Oh Raider, not going well is it? That statement translates as 'I have already ordered more.'
Remember a penetrating hit is not always needed - plenty of British tanks "lost" in the Desert due to the crews bailing out when "plinked". Poor design meant it took 5-10 minutes (or longer) for the crew to get out, so if it looked like trouble, they bailed early and often. Driver losses were still horrendous as they couldn't even start to get out till the main fighting compartment was empty as they had to eel out through the seats, gun, gear and out the space the turret crew were in.
Also watched an interesting video on ammo expenditure required to "kill" (depending on tank/weapon/era, that's bailed and can be reoccupied in ten mins", "needs the LAD to give it a bash" "requires the REME to drag it back to the repair base", to "actually a write off") an AFV in WW2 - it's pretty bad; never mind the usual "three rounds and then another if it's not on fire" approach, even the much vaunted 88 averages out at @12-15 rounds per kill!
I'll see if I can trawl my Youtube history for it.
Ah, here we are, I think this is the one -
His one examining the German examination of the Churchills lost at Dieppe is interesting and quite relevant as well!
Intereasting stuff there, think you would need to look at the tactical situation as well. For instance was %02 SwPnzAb defending when it scored at 6.5, so at knpw ranges on exposed targets. I doubt if it is possible to find the accurate number of rounds fired per target kill anyway.
