Portees
Started by Amra, 02 February 2021, 03:11:44 PM
Amra
Hi All ,
Moving on to the 8th Army, I know portees have been discussed but I can't find the final answer
Do they move,deploy,shoot ? So their only advantage is speed ? Their disadvantage being 3 hits
Are they based on a standard vehicle base ( as opposed to a gun base) ?
Ok the Portee was supposed to dismount to fire, but the crews often didn't. To dismout it needs a Delpoy order, and similarly to move off. However to fire with it mounted just issue a fire order. There is an argument that it should be limited traverse but as the 2pdr has 360 traverse I would'nt. One RA officer Lee? Gunn won a VC during the Crusader figthing, he was killed, for almost halting a complete Pnz Coy with one Portee.
holdfast
Is a Delpoy Order like a Delboy order which requires it to divert to Peckham?
Amra
So it operates like a tank ?
Ok, and base size ?
Base size does not really matter as you measure to the center of the base
Amra
Probably does a bit for hiding behind terrain and getting caught under arty/air
Yes it's a soft skin open toped AFV
Quote from: ianrs54 on 03 February 2021, 09:18:03 AM
Yup - that is short hand for "artillery or mortar magnet" & "almost certain death!" But it can get a few telling shots off.
When firing mounted I would treat as Restricted Arc - so 45 degree either side of the centre of the back of the truck.
Amra
Haha yup sounds right
I guess with forces in the desert based around before June 1942 , the DAK look so strong I'm hoping a 'target rich environment" will mean some 8th Army get thru !
Ariete
Quote from: Lord Kermit of Birkenhead on 02 February 2021, 04:15:12 PM
Ok the Portee was supposed to dismount to fire, but the crews often didn't. To dismount it needs a Deploy order, and similarly to move off. However to fire with it mounted just issue a fire order. There is an argument that it should be limited traverse but as the 2pdr has 360 traverse I would'nt. One RA officer Lee? Gunn won a VC during the Crusader fighting, he was killed, for almost halting a complete Pnz Coy with one Portee.
The Bofors 37mm Portee has no traverse worth mentioning and was always rear facing afaik
The 2pdr cannot traverse as far as the platform allows because the crew have nowhere to stand once it get to about 75 degrees from the centre line and the gunners seats and ready ammo are behind the cab.
On Morris conversions they just wheeled the 2pdr facing forward and served the gun from behind.
Apart from the Deacon the 6pdr Portee was usually loaded facing over the cab OR over the rear end.
I would give all British portees restricted arc because of this [except the Deacon with the armoured gun house]
Link to a Google image search that shows lots of photographs of 2pdr portee guns deployed for action.
https://www.google.com/search?q=2pdr+portee&rlz=1C1CHBF_en-GBGB905GB905&sxsrf=AOaemvLfzrwed2uDOwJmjskZqr5xfMoqNg:1630522495173&source=lnms&tbm=isch&sa=X&ved=2ahUKEwj_0f3Qud7yAhWQilwKHReHBT0Q_AUoAXoECAEQAw&biw=1920&bih=937
6pdr Portee pictures
https://www.google.com/search?q=6pdr+portee&tbm=isch&ved=2ahUKEwiOoMvUud7yAhXPwoUKHWEuDOwQ2-cCegQIABAA&oq=6pdr+portee&gs_lcp=CgNpbWcQAzIGCAAQBxAeUKndJliH5CZg_eomaABwAHgAgAFUiAGGAZIBATKYAQCgAQGqAQtnd3Mtd2l6LWltZ8ABAQ&sclient=img&ei=hswvYY7FLM-FlwTh3LDgDg&bih=937&biw=1920&rlz=1C1CHBF_en-GBGB905GB905
37mm Bofors Portee
https://www.google.com/search?q=37mm+bofors+portee&tbm=isch&ved=2ahUKEwjLsMWzvN7yAhVNMRoKHYTgBHMQ2-cCegQIABAA&oq=37mm+bofors+portee&gs_lcp=CgNpbWcQA1DTqwNY06sDYIDTA2gAcAB4AIABQ4gBQ5IBATGYAQCgAQGqAQtnd3Mtd2l6LWltZ8ABAQ&sclient=img&ei=Zs8vYcvlLM3iaITBk5gH&bih=937&biw=1920&rlz=1C1CHBF_en-GBGB905GB905
French 25mm Portee
https://www.google.com/search?q=25mm+portee&tbm=isch&ved=2ahUKEwj5wovfvN7yAhWH44UKHXQfAQ8Q2-cCegQIABAA&oq=25mm+portee&gs_lcp=CgNpbWcQA1DnGFjVIWCMKGgBcAB4AIABP4gB2AKSAQE2mAEAoAEBqgELZ3dzLXdpei1pbWfAAQE&sclient=img&ei=ws8vYfnZA4fHlwT0voR4&bih=937&biw=1920&rlz=1C1CHBF_en-GBGB905GB905
Drew
