Scratch Built Aircraft Hangar
Started by Steve J, 17 January 2021, 08:50:18 PM
That's awfully clever!
Shouldn't you have two of them?
I've kept the other half in case I want to make another, but am concentrating on getting one finished first.
Made a load of HAS in 1/300th from the centre of toilet rolls...
Techno II
What a stunningly simple, but brilliant idea.  :-bd
I love it !!
Cheers - Phil  :)
Thanks chaps :). It just came to me when washing up in one of those light bulb moments! Also as a wargamer I'm always on the look out for 'stuff' that might be useful for terrain etc.
Well done, looks the part for being such a simple object to start.
@ Orcs: I simply put it in a vice end on, then carefully sawed down one length, turned it round 180 degrees and repeated along the opposite side. For the base I used a cutting disc in a dremel so as not to damage the halves as they are easy to bend when the structure has been cut. Hope this helps?
Thanks , I thought as much, but wondered about it loosing its integrity
What a Fab idea Steve - looks great at 10mm - might also work for 6mm I suspect.
I am looking forward to seeing the finished model.
You might need a small metal chimney for the stove in the back office?
Inspiring  :)
