Greetings all
Started by Smithy, 04 January 2021, 09:46:59 PM
hammurabi70
Quote from: Chris Pringle on 05 January 2021, 10:29:57 AM
Smithy, welcome to the Forum. 10mm - good choice.
It's the 225th anniversary of Napoleon's glorious first campaign! Is that inspiring enough? Some fascinating battles, and very do-able because the forces are relatively small. In fact mine were really small as I fought 1796 in 2mm:
http://bloodybigbattles.blogspot.com/2018/04/lodid-dice.html
Chris
Bloody Big BATTLES!
https://groups.io/g/bloodybigbattles
Inspirational stuff. How do you base and mark the units? Small units are difficult to differentiate.
Scorpio_Rocks
Welcome on board Smithy!
We all love us some pics - look forwards to you posting them
Horatio Nelson.
Chris Pringle
Quote from: hammurabi70 on 07 January 2021, 09:11:51 PM
Sorry, hammurabi, missed this until now. Answer is:
All my 2mm units are on 2" x 2" bases.
The games are small enough (about a dozen units a side) that marking them isn't really necessary. All the bases are numbered, though, so I sometimes mark them on a roster so I can check which brigade belongs to which general if I really need to. There are other things that can be done to aid quick and easy visual ID, eg some units might be based as ordre mixte, others in columns, etc. Then you can say all the ordre mixte are 1 Corps, all the massed columns are 2 Corps, the ones in white uniforms are 3 Corps (etc).
Chris
hammurabi70
Quote from: Chris Pringle on 10 February 2021, 07:32:30 PM
Chris
Many thanks.  I am using 40mm x 20mm but the marker strip at the back is 6mm so I only have 14mm for the figures [2mm].  Even two ranks of cavalry are a tight fit.  My current struggle is dealing with the artillery.
Roel
Welkom / Wilkommen / Welcome!
