How many flags in an 1809 Austrian Infantry Regiment
Started by Duke Speedy of Leighton, 03 June 2020, 10:54:16 PM
While I've got your attention...
Colonels, brigadiers and divisional generals in the infantry...
The Pendraken mounted Hungarian officer is on his coat, brown on the website, is that universal or just artillery?
Senior generals white with red trousers etc?
Cavalry I'll ask another time.
Ta in advance.
I've gone with White with Red for my Generals.  The 2nd man on the command stand white trousers, ie standard dress. Hungarian officers (not generals)  white/blue.
I'm probably wrong.
Quote from: mad lemmey on 17 June 2020, 05:42:56 PM
Ta in advance.
Hi, more or less I think.  General officers (Generalmajor upwards) white with red breeches, field and junior officers (Oberst and below) the uniform of their regiment.  The officers' uberrock, what we'd call a frock coat I think, was grey, really quite dark verging on charcoal in all the pics I've seen.  If I remember correctly the colour was termed wolfgrau for what that is worth.
Zippee
Quote from: mollinary on 17 June 2020, 10:46:36 AM
Wasn't the answer contained in a very early post?  Austrian Battalions had two flags per Battalion from 1792-1805, and one thereafter. So after 1805 50% of the existing model 1792 flags, all ordinarfahnen, would be surplus to requirements. Or have I missed something as usual?
Well no not quite but sort of. The change to a single flag in 1805 was temporary and as the number of battalions increased merely absorbed the existing flags (if there were numerous 'spares' why the need to reduce to a single flag?)
The reduction to a single flag was in 1808 post the 1806 redesign, perhaps to make the resupply cheaper? Anyway lots of flags were lost in 1805 so we can't really confirm a significant surplus created by this reduction. I can also imagine that lost flags would more likely to be replaced by new designs and serviceable 1792 flags being retained - both as a cost saving and as a not-so-subtle statement of "we didn't lose ours"
But none of that matters as we are still supposed to believe in a surplus of ordinarfahne to equip the combined grenadiers prior to 1805 - and it is described as a surplus flag (although that may be a repeating misquote from some secondary citation. I note JC quotes DH without using the term but it's still not "the grenadiers' flags were kept at depot until required"). I'd quite understand that the grenadier flag was retained at depot until the battalions were formed in time of war but I doubt I'd describe that as a surplus flag.
Austria is legendary for its parsimony but also seems to be the only nation with surplus flags lying around in case of need, weird.
WeeWars
Ta in advance.
The Hungarian colonel - go with a grey coat, keep brown for your artillery, as you say.
www.michaelscott.name/1809/1809blogpost127.htm
Generals -
www.michaelscott.name/1809/1809blogpost157.htm
Senior officers could also wear grey over-trousers - see the link to Post 139.
www.supremelittleness.co.uk
Yes, as I understand it there were two reductions to a single flag per battalion.  The first in June 1805, with a return to the two flags per battalion in the interim in December 1806, and a second reduction in 1808.   Hope I've got that clear, in my own mind as much as anybody else's.  The flags no longer required were held at the depot or, as suggested elsewhere, in chapels or churches at the seats of the inhaber.  This pretty much the usual thing to do with military artefacts of this kind.  But, where they were held is not important.
Those taken out of use in 1805 would, we can reasonably assume, be taken back into use in 1806, and could also be used to replace flags lost between October and December 1805.  Those taken out of use as a result of the 1808 reduction would have been available in 1809.
Working out how many ordinarfahnen might be available, potentially, in 1809 is a matter, I think, of arithmetic.
Prior to the reduction to one flag per battalion in 1808, I think we agree that a regiment had one leibfahne and five ordinarfahnen. One leibfahne and one ordinarfahne for the 1. or Leibbataillon, two ordinarfahnen for the 2. or Oberstsbataillon and two ordinarfahnen for the 3. or Oberstlieutenantsbataillon.
In 1808 there were, according to the list I have in front of me, 63 regiments.  Assuming all had a full complement of one leibfahne and five ordinarfahnen (I concede they might not) and that each returned three ordinarfahnen, retaining just two, one for the second and one for the third battalion, I calculate that comes, in theory, to a maximum 189 ordinarfahnen that were surplus to requirements.
Even if you assume that the losses at Ulm (45 of all kinds) and Austerlitz (?) were made good from this figure, it is still going to leave a substantial number available in 1809.
A similar reduction, resulting in eagles and flags that were no longer required, happened in France.  It is not a unique occurrence and these kinds of artefacts are not usually thrown away.
As for what happened with grenadier battalions before 1805, I have no idea I'm afraid.
Zippee
Quote from: John Cook on 18 June 2020, 02:07:22 PM
That seems plausible, but just to add some numbers in:
In 1793 there are 57 IR plus 2 garrison regiments (5 & 6) with an establishment of 3 battalions (4 in Hungarian regts, 2 in the garrisons) each with 2 flags and at least 1 "spare" for use by the grenadier companies if they are the senior regiment of the combined battalion. I have no idea how many flags the garrison regts had but the 17 Grenz IR (2 or 3 battalions each) each have 1 leibfahne and 1 (or 2) ordinarfahne issued (officially not be carried on the field - again no idea if that was actually the case).
In 1798 the 4th battalions of the Hungarian regts are combined to establish IR 60, 61 & 62 so all 60 IR now have 3 battalions (shouldn't impact the flag ration, although presumably we now have the need for 3 more leibfahne)
In 1805 a single flag is issued to each battalion in the new 5 battalion organisation - so we have at least 2 "spare" ordinafahne in depot but this is a very temporary thing
In 1806 things revert to 'normal' so three battalions with 2 flags and at least 1 "spare" for all 60 IR, plus the garrison battalions plus the GIR allocation (which by 1807 appears to be 1 ordinarfahne per battalion, don't know what happened to the leibfahne, re-assigned perhaps?)
In 1808 the allocation is reduced to 1 flag per IR battalion, in theory that should produce 180 "spare" ordinarfahne in addition to the 60 "spare" grenadier flags - so a max of some 240 give or take (maybe the GIR gave up their leibfahne for spare ordinarfahne at some point)
From that we deduct losses from all campaigns (surely not more than 1 per regiment when averaged I would think) and add the new flags decreed in 1806 and issued prior to mobilisation in 1809
In 1809 we have in addition to the 60 IR and 17 GIR the 17 grenadier battalions in I & II Reserve Corps plus 2 others, so that accounts for 19 "spare" grenadier flags
There were something like 70 odd landwehr battalions raised that I'm aware of so that's another 70+ "spares"
Then there are friecorps and units like the EKL (6 battalions) - some of these may have carried individual state flags, some may not have had any as jager equivalents but lets assume they got a "spare" and call it another dozen or so.
All-in-all that doesn't ad up to much more than 100 allocated "spares" - it would seem highly likely that even taking losses into account there would be more than enough spare flags from the 1808 reduction to account for that allocation.
Then there's the Insurrection troops - I have little info on them and no idea if they were issued flags or not nor in what numbers but I don't think they would have depleted stocks judging by this accounting (rough and ready as it is) or at least I don't think they would care if they had no Austrian flag to carry :)
Flags added, now I've got to edge them, tanned Austrians and their beautiful vandyke edge designs...
Zippee
I find a black sharpie does the job - I do the edge after cutting and before folding/gluing, it's a tad harder once added and curled into shape  ;)
I carefully apply a very thin amount of paint to the edge of the flag when fixed in place but one technique which I have yet to try and recommended by at least one of the flag suppliers is to paint the opposite side edges of the flag before folding and fixing to the figure. Has anyone tried that and with what success?
Not tried that method - but it sounds only good for misaligned halves, rather than the cut top edges. I find painting the edges of the flags once in position pretty easy, but I don't go for too creative a set of folds for the flag.
