Hundred Years War - DBA
Started by paulr, 14 May 2020, 08:05:38 AM
Finally got a chance to make some more progress :)
Clothing done on Scots men-at-arms and detached "gross varlets"  :)
I also tested Vallejo Acrylic Matt Varnish on an element of peasant levy, the 'local' game store has been unable to get stocks of Testors Dullcote :-SS
Unfortunately just after I sprayed them it clouded over, there was some slight fogging on the figures which dried clear #:-S :-\
However there was significant fogging on the printed label at the back of the base. I remembered some advice, I think it was on here, and gave the label a second spray. This reduced but did not eliminate the fogging :(
I'm going to have to wait for a calm sunny day to do another test before I commit to spraying a whole army :-w :-SS
Fined up this afternoon so tested a second element, Jaquerie this time
Just checked and figures are fine but label badly fogged again, tried a second spray on the label and will see how it drys
Any thoughts/suggestions :-\
How long should I shake the new spray can...
The second spray on the label reduced but did not eliminate the fogging  :-/
Figures and flock are fine :)
Techno II
If I'm understanding correctly, Paul, (not taken as a given).....I don't think shaking the can even more will make much difference.
It sounds as though there's a bit too much 'medium' in with the varnish itself.....The more you shake the can the more medium is going to get mixed in.
Only tip I've got, is what I used to do to test a new can of varnish.....Which was simply to spray a little over an old newspaper... for me, it was to test the print didn't go 'glossy'.
However....If you've got any of the 'glossy' magazine inserts*, that come with the weekend papers....You might be able to tell if it's still too 'foggy' ?
Cheers - Phil (* I'm assuming you get the same sort of inane crap that we do with our papers, over here. ;))
Quote from: Techno II on 13 December 2020, 08:35:33 AM
Other types of glossy magazines are available, though I'd like to hear you explain to the wife why the pages of her copy of Cosmo is stuck together.
I use a base. Paint it in the predominant colour of the figures I'm painting). Mask half of it. Varnish the other.
Where spray can varnish has fogged  (three times in a couple of decades iiirc) I've always used brush on varnish to rescue it on the adage that doing the same thing and expecting a different result is the route to madness.
Brush the labels (only) by hand and see?
Of course, 3 times is hardly a large sample size.
Thanks for the suggestions, I'll have a look at getting some brush on varnish and trying that on the labels once we get some good weather
Good progress on the current batch of French :)
Commoners clothing done :)
All wood done :)
More progress on the current batch :)
Manes, tails, hooves & markings done on the horses :)
Hats and leather done :)
Various dry brushing on the artillery 'extras' :)
I might make some more progress this evening :!!
I need to start sorting out and preparing the next batch
Do I start on the second French army (banners and colours all sorted) or do I start on the Low Countries (some research done but not finalised) :-\
I'd go for the Low Countries Paul to have something different to paint and game with.
The trouble with matt sprays is that particles can dry before they hit the surface they are supposed to treat.  These dried particles of matt varnish are left on the surface, while the rest are absorbed, causing the fogging which increases depending on how absorbent the surface is.
This happens when the nozzle is too far away from the subject relative to conditions – too hot, too dry or too humid etc.  The trouble is there is no way of knowing what the correct distance is.
A solution, if you are going to use spray varnish, is to seal the object first, reducing the surface's absorbent properties, with either a painted gloss varnish or PVA glue thinned with water.
Fogging is usually not the end of the world and can usually be rectified.  What you need to do is to dissolve the dried varnish particles on the surface of the object, which can be done by brushing on a coat of gloss varnish, allowing it to dry, and then re-applying the matt finish.
My solution to this problem is not to use spray varnishes at all.
Thanks Steve, I was thinking the Low Countries would be a change given I stalled on the French
Thanks John for the detailed explanation, good to know what is going on
Fogging (or blooming as we used to call it at work) can also be caused by moisture trapped by the lacquer as it dries. As mentioned, another coat when the conditions were drier often solved the problem. This is one reason I use Vallejo matt lacquer painted on, rather than spraying it.
Quote from: Steve J on 27 December 2020, 09:47:55 PM
Yes, humidity is often the most common culprit.  You can get a similar problem with aerosol spray paint when you get a rough finish on the dried surface.  I agree, using a paint on matt finish is safer and better.  I too use Vallejo matt varnish these days.
I've finally finished painting this batch of French #:-S
Touch ups, wash, final dry brush, figure bases & basing left to do :!!
I've started preparing the first batch of the Low Counties army, Pike - thousands of them, 64 actually ;)
Touch ups done :)
Wash tomorrow once they are properly dry :-w
Finished preparing the rest of the Low Countries army :)
Not many optional elements so only 16 in total compared to 36 for the French #:-S
Biological or non-biological?  :D
Most of the Low Countries pike on painting rods, the rest will have to wait until the French are sorted for basing tomorrow, not sure if all the army will fit as one batch :-\
Bases for the French labeled :)
First side done on Low Countries bases :)
Final dry brush done on the French and figure bases done :) :)
Second side done on Low Countries bases :)
