Churchill Crocodile
Started by Cross698, 21 May 2019, 11:29:02 AM
Cross698
In the British List the Crocodile is not "TOUGH" unlike the Churchill Mk VII. Is this to reflect the armoured trailer? :'(
Yes.
Hits on the trailer will usually KO the tank (apparently) and I suspect that any other AFV flame-throwers are all equally vulnerable.
In fact I did at one point consider the idea that an exploding fuel trailer would also suppress (automatically) all other units (friends & foe alike) within 5cms. But that might have been seen as a bit too granular.
Cross698
Thanks. The drivers were trained to negotiate the tank in such a way as to keep the trailer protected, so you could argue that the movement of a Crocodile was only 10cm, rather than 15cm. Well the German Players at our club will be happy! :-
Quote from: Big Insect on 21 May 2019, 11:33:46 AM
I thought that the Crocdile was designed so that if the trailer was disabled it could be disengaged from within the vehicle, and the Churchill could then fight as a normal gun tank.
Dr Dave
Yep, the trailer can be ditched and you're left with what is a mkVII minus the bow MG.
I assume that the trailer is low profile if it is being targeted and hence making the Churchill non-Tough?
Cross698
Can you target the trailer separately? Probably easier to just have the stats as it is. The armoured fuel pipe went under the tank and then came up into the firing position and believe the trailer could be disconnected from within the tank. Certainly the Bobbin had charges that could be operated from inside the tank. I suspect the Churchill was safer than the Panzer III flame tank or any other tank that had the fuel contained within the body of the tank. But although dodgy either  , at least the Churchill had good armour.
Nope - you cannot target the trailer separately! The cheek  :'(
Far to granular for what we are looking to achieve.
It's triggered an interesting thought though ... I wouldnt want to be an Infantry unit assaulting a Crocodile or any other AFV flamethrower unit ... as the risk of self-annihilation would probably have been quite high  :o
Cross698
21 May 2019, 03:08:14 PM #7 Last Edit: 21 May 2019, 03:17:08 PM by Cross698
Perhaps a template explosion! Any unsaved hit roll one dice and on a score of 6 it goes up! Could be the basis of a scenario!
Dr Dave
Quote from: Cross698 on 21 May 2019, 03:08:14 PM
So you can't target the trailer. But Jerry does get the benefit of it not being as well armoured as the tank -  like he is targeting it, except without the disadvantage of it being low. I'd point out that it's a troops of 3-4 vehicles all having their trailers targeted. Is it drifting from a bttn / brigade level game into skirmish?
Cross698
Well FWC does have suggested skirmish rules!
Quote from: Dr Dave on 21 May 2019, 03:59:54 PM
. . . I'd point out that it's a troops of 3-4 vehicles all having their trailers targeted.
Well, it could be. I've always looked at it as 1:1 on vehicles/guns etc., and 1 stand = 1 section/squad for infantry.
Otherwise the vehicle units don't make any sense to me.
Wulf
21 May 2019, 06:49:00 PM #11 Last Edit: 21 May 2019, 07:03:40 PM by Wulf
Everything you ever wanted to know about the Churchill Crocodile...
Cross698
Very good. Bovington is a great museum.
Dr Dave
Since the trailer is the source of its vulnerability in the rules compared to a normal mkVII if it dumped the trailer after flaming it would revert back to being tough.
Wulf
Quote from: Cross698 on 21 May 2019, 07:02:12 PM
I added another video
