Hearts of Oak (well MDF...)
Another lesson.
Don't undercoat the horses. The MDF is a nice chestnut colour, and now I've got to paint the coats again. Will just use white paint pen to undercoat just rider and tack.
Only one side is smooth, the edge is ridged. Not too bad on infantry, but there is a lot of horse to paint/colour in.
A wider nibbed pen might help - splot for each side of the horse (sort of rump-left- rump right), think stripe down theoutaide  legs, same at front? "Gaps" left for a suggestion of tack and reins etc.  Although if you've undercoated white that doesn't really work, I guess and you're stuck with actually painting the beasts? But at least you can colour in the saddle cloths etc!
Anywhere that has been cut is rough, this includes the "front" f the head and tail on the smooth side where the wood has burned off to make it thinner.
For the next lot of horses I'm literally going to colour rider and tack in white, then go over only them with colours.
Yeah, I know, I've a load of them :D
I guess the cut MDF is probably close enough, and it should work well with the paint pens for colouring in the detail.
Just thinking about what's going to be quicker but "undercoating" with a pen for just the tack & rider is probably as quick as spraying anyway, I bet :D
By the time you've repainted its not worth spraying.
Glad I bought test strips before spraying a hundred more horses!
Shutuphippie
Walt's flats are fab. I painted up some Austrians for him when they first came out and we were playing a rather large Volley and Bayonet  Napoleonic campaign. 😁.  Not that he needed much help btw as his own painting is utterly superb, the man has the eyes of hawk.
I have just received my copy of the 100th WSS mag and they have a nice little review of the figures  in that 😁 so fingers crossed he'll pick up loads of orders from that
2018 Painting Competition - Winner!
I do t do them justice.
Mind you, I say that about a lot of figures...
So, I'm turning this into my 'project thread'.
French army 'recruiting' courtesy of Walt.
Have ordered (surprisingly cheap) movement trays from a certain 'Dark Lord' as Nobby insists on calling him. Most helpful with my desire for some non standard ones for Commanders, along with a big pack of 40 x 20 bases, plus 20 and 40 x 10 for the markers. I've over sized the move trays to allow the markers with unit info (name, division, traits etc) to be placed along the back.  Commanders will be on 40mm disks with up to 3 AdCs to act as Command Point markers
(actually worried that what I asked for isn't what I meant! What if my diagram of the Command bases was duff?)
Have been fiddling with using acetone/alcohol pen combo to transfer laser prints onto painted mdf. Its not really suitable. Its hard not to rub the paint off or leave bits of the paper behind.
(Laser print/photocopy something mirror image, Place on surface to take the print, use acetone to soak the paper, and blender pen to activate the process - acetone on its own doesn't work.)
So have bitten the bullet and bought laser printer water slide decal paper to make up the markers. Also experimented with a white gel pen, but not sure I can write neat enough on a couple of hundred bases.
Just waiting for lots of MDF to drop through the door now, bases, trays, soldiers and storage trays! Landlady says its my job to sort out food for a couple of thousand Frenchmen and stabling for a couple of hundred horses!
Of the test strips - Finished the Empress Dragoons, but as of yet, no bases! They don't look quite as thin painted! The two I didn't spray undercoat definitely look better. Photos when the bases arrive.
Started on the cannons. Think I might try my pin vice drill on the hub to put a pin in to mount the wheels rather than glue alone.
The OOB im working too has the hussars - 5th and 6th in sky blue. I think I will do an AdC as the 8th, so it looks like the little chap on the left.  Luckily AdCs cant be shot - they are just point markers, or Orcs would insist on playing me just so he could shoot the Little Hussar!
 ;D
I found glue alone fine with the cannon, limbers etc - once glued to a base as well they're small enough but with enough area to join they won't break. Well they might but only if you stamped on them or something.
Good luck with the bases etc :)
Did you sketch it out in the pub? Blame the beer if it goes wrong!
No- working out stuff for Wargames is why the Civil Service has computers.  :d
Likewise photocopies and printers.  How do you think I know about all the extra facilities - mirroring images, making booklets etc - our photocopier has?  ;D
My taxes, my taxes!!! - Oh, hang on though, schools are great places for photocopying and laminating. :-[
Useful skill transfer into the work environment ;)
Almost finished the three test packs. The edges of the gunners will need properly doing once clipped apart; the line will have to take their chances, but  because the crew be around their pieces their edges will be seen. Not clipping until ready to base, and I'm in Leon and the Royal mail's hands on that.
Had trouble getting wheels to stick. After I've done all four I wondered about gluing a thin wire Axel on the underside, and going with my idea of drilling the hubs.
The re are 2 lengths of barrel, the shorter barely clears the carriage. Any oine know what it is meant to represent?
I agree. Issued by the British at one per battery, though Bull's Battery at Waterloo were all howitzers.
Indeed, howitzers IIRC Walt's comment before correctly.
Odd on the gluing - I just superglued the wheels on and was done?!
My glue must be a bit dodgy. Took time to set
To be fair smooth to smooth no lugs is always tricky and I've various stuff that probably would fall apart before it set unless I clamped it :D Assuming the glue came out the tube at all ;)
A light sprinkle of Bicarb of Soda or Baking Powder will almost insta-set superglue. Very useful for fiddly joins ... and for gluing bits to your fingers if not used carefully :)
