Facebook: Friends of the Tank Museum
Started by fsn, 20 July 2018, 12:53:28 PM
IIRC the British had camo patterns to follow, as I've seen the same on early war tanks where they all have the same pattern, near as damnit.
Thats true Steve. You see Grants, Shermans and Crusaders with the white outline to the brown because the crew had not painted over the full area outlined by the engineers. Most armies do have standard patterns - even for MERDEC, one of the reasons it was withdrawn is that the crew painted vehicles were none standard.
Char B1 in German hands.
For some reason I imagine the chap sat there sounds like this ....
Quote from: fsn on 16 March 2021, 08:35:44 PM
Obviously the inspiration for all those "woman in bikini lying on the bonnet" pictures you used to get at car launches/motor shows.
I've spent most of today failing to find an armour schematic for the Char B1bis showing the actual plate thicknesses for each part of the tank.
Sources don't even agree on the flat plate thickness of the hull side (it's either 55mm or 60mm).
The turret sides and rear are apparently 56mm thick, but it's the various parts of the turret front and hull front with their varying angles that I'm after.
This pic here shows the turret varies, but not the actual values
https://warspot.net/68-char-b1-bis-general-estienne-s-legacy/images?name=%2F000%2F000%2F887%2Fcontent%2Fcharbp3s01-0ca88fa558e13ea670e15271cd54d15b-89e0ff6185b7c27b4d13e9c972bb4912.jpg
For instance the MG mantlet is actually spaced armour, but the plates are considerably thinner than the 56mm turret side plates. Normally this wouldn't matter but the MG port mantlet is so a huge part of the turret front that plenty of shots aimed at the turret are gonna hit the thing.
I've managed to find the equivalent data for the Somua S-35 and it's quite startling how the Line of Sight thicknesses vary when facing frontally.
The Centurion was first used in mid-1945, when six prototypes were sent to Germany at the end of the Second World War. The production standard Mark 1 entered service in 1946. Only 100 Mark 1s were produced, subsequent versions were more heavily armoured and used a different design of turret. This no longer featured the unsuccessful independent machine gun.
It looks very like a Comet from this angle - especially without the side skirts
Quote from: fred. on 18 March 2021, 09:00:06 PM
Well that was its heritage
"Look Sir T-34's advancing from the East....hundreds of them!!"  ;)
Thats very much a photo of two halves isn't it?
On the left four members of the Cent's crew sit/stand idly waiting for the small "O" group on the right to decide their next move.....
Looks very like the one contour on Salisbury plain
Most Indian Army units fought loyally for the British, but small units were raised to fight against them by both the Japanese (the Indian National Army) and the Germans (The Free India Legion).  The latter was raised from an initial core of political exiles living in Germany, supplemented by Indian POWs captured in North Africa.  They mostly served as internal security units in western Europe, though some saw combat against British and Polish troops in Italy.  These men are manning an MG34 position on the Atlantic Wall near Bordeaux several months before D-day
:o
Certainly surprising the Nazis would want such a thing.
Quote from: Raider4 on 31 March 2021, 05:10:54 PM
I intend no credibility toward the insane Nazi doctrine, but I understand that some took the whole Indian / Aryan / Swastikas thing quite seriously.
You'll always find these master race types creating bizarre exceptions.
Ace of Spades
The nazi's were smart enough to set people up against each other. Indians versus the British imperialists, Bosnian Muslims versus Jews, Ukrainians and cossacks against communists etc. As long as they would help them out they were welcome. How they planned to deal with them after the Endsieg luckily remains to be speculation. I don't believe they would have been given huge rewards...not much exceeding a 7.62 I fear.
Rob
With the recent Defence Review, the British Army is going speed up the arrival of the 8x8 wheeled Boxer APC, which will replace the existing tracked Warrior IFV.  The Boxer is a joint German / Dutch design, and is already in service with those countries, Australia and Lithuania.  The UK had originally been a participant in the Boxer programme, but withdrew to develop its own "Future Rapid Effect System" programme, then rejoined in 2018.  The most notable feature of the Boxer is its modular nature – the same chassis and drive unit can be fitted with one of several "mission modules", which can changed in less than an hour, allowing the fleet to be reconfigured for changing needs at relatively low costs.   There are currently 15 different mission modules available, including APC, ambulance, command post, 30mm cannon turret, mortar carrier and even an autoloading 155mm howitzer.
Can't help thinking the new camouflage scheme has even fewer uses than the Berlin scheme.
Quote from: fsn on 03 April 2021, 09:23:55 AM
Oh, I dunno, You could hide it in the background of a Tory minister's Zoom meeting. And there's probably still a few kerbs in Belfast that it could be parked alongside and just meld in?
T13A
Was it just me that on first inspection it looked as if it was made out of Lego?  ;)
Cheers Paul
T13A Out!
Well you don't think the current govt would buy an armoured vehicle, far too sensible  :'(
Six Avro Vulcan B.2's and six Handley Page Victor B.2's lined up at RAF Scampton in their 'anti-flash' white paint scheme.
There's lovely!
