Spanish 10mm batch nearly done,  just a few touch ups to do ...
Spanish shooty foot done.
Bases sanded and pva'd.
Next three batches of 28mm built.
Napoleonics:
28mm French done, 6mm French infantry batch done (apart from tidying up).  6mm French Cuirassiers nearly done.
10mm Austrian artillery, frreikorps cavalry and command stand built.
28mm/40mm French done.
6mm French infantry done. Bloody hard.
10mm artillery base coated and inked, Spanish bases inked at the same time.
Burgundian pikemen nearly done, Lancastrian artillery lined up for painting, two units of crossbowmen hot to be shot.
4 regiments of cuirassiers, 4 regiments of Dragoons, 4 batteries of artillery in 6mm finished today. Plus a 28mm Lowlander unit for the '45 up to the basing stage. A 28mm foot knight from the 80s ug out from the shed, sorted inkrd, highlighted and based for a mate along with two halfling rogues for our on-going D&D campaign have been completed.
Doesn't sound much, but kept me busy all day.
Herbert and Neville are raising the first longbowmen of many.
Waiting for glue and varnish to dry before photo session...
OK, I know I'm not right in the head ... but I thought of this ...
Techno II
What on Earth ?  :o :o  ;D ;D ;D ;D
Cheers - Phil. :)
Half the next batch base coated and inked.
More research needed before I commit to the second half.   :-B
Neville and Greystoke retainers based; Scrope and Percy up next,
Other half of batch basecoated and inked.
Phew
Techno II
I hate two man machine gun teams...unless the gun happens to be being used in a prone position.* ~X( ~X( ~X(
I gotta headache. X_X
Just the loader's arms to finish....(It had better work, or there will be some very industrial language.)
Cheers - Phil. ;)
* Those are a piece of absolute wee to make, compared to this one.
What type of gun ? An advancing Bren would have the weapon in the left hand by the carrying handle, not by the underside of the barrel, that gets rather warm. No 2 would be carrying one or two boxes, each with 10 mags in, rifle slung. BAR - no number 2, used as a one man weapon. Germans - similar although the the no 2 often only had a pistol, and would be swathed in belts. The gun has no carrying handle (both types) so would have to hold by the bipod.
Which nationallity you doing Phil.
Techno II
That Goryunov, Ian......I've made at least 15 other figures while I've been playing with this one this one, off and on.
I keep looking at it...thinking....Nah, I'll do something else......But have at last decided I'll have finish the swine off.  ;D ;D ;D
It's for the Egyptians, Matey.
Cheers - Phil. :)
Thats a wheeled mount then - gunner on the trail and loader kneeling on lying to left/right depending on the feed. Should be no trouble with that one.
Techno II
Thanks, Ian. :)
I've 'copied' an old b/w piccy of the gun itself, that's sitting on top of an outcrop of rock......so  the trail would go through the gunners stomach, if it went straight back.
It's almost as if they're using the rock surrounding them as a big foxhole
He must have the trail angled to his left...which is what I've done......He'd still have a decent firing arc, I guess.
Loader's on the left side on this particular gun. (Apparently.....That was a pain as well.  ;D ;D ;D)
Cheers - Phil :)
