19 catafracts and 1 cat assembled to reinforce my Sassanids.
4 more Hobbits found and built.
11 28mm pikes finished (bar basing)
Night all
(Or morning, deepening on time zone)
Quote1 cat assembled to reinforce my Sassanids.
I'm intrigued... :D
Quote from: mad lemmey on 04 March 2020, 12:02:33 AM
19 catafracts(sp) and 1 cat assembled to reinforce my Sassanids.
Night all
Will even I know that Cataphracts is spelled wit a ph and not a f !!  :d
Dependz if yaz sayz it proppa!   8)
4 28mm hobbits, 19 Mortal God's Spartans, 19 10mm Catafracts and their cat base coated and inked last night.
NKE are flocked and are being envegetated too.
Spartans and Sassanids highlighted.
Just details to do
Quite a lot of details added, but still not finished.
I have already added basing materials to these, so one lot highlighted, two inked today too.
NKE are go, Gauls on the table.  Yo, I be like on a roll, bro.
More drybrushing of ImagiNations units, to try and catch up with Dave whose Army has mobilised far more quickly than mine :o!
First unit of Zouaves base coated and washed.
Sassandids basically done, rest nearly done...  :P
Gauls done up. Achaemenids following on shortly.
Done apart from shields and flock etc...
Shields base coated and inked,
8 Star Wars Armada Scum and Villainy starfighters base coated and inked too.  8)
1st unit of Zouaves finished, 2nd unit started.
Fronds sprouting from most Achaemenid bases now.
A good blob of green stuff used to (hopefully) mend a crack in one of the water butts.
(Well....green stuff was originally designed for use as a 'plumbing putty' !) :)
