New club in Tunstall, nr Richmond, North Yorkshire.
Started by Bodvoc, 26 August 2016, 03:22:24 PM
skywalker
Roy, I am surprised we didn't cause his camera irreparable damage  ;D ;D ;D ;D
Quote from: Bodvoc on 08 September 2016, 11:11:49 AM
the ancients will actually be 6mm Greeks and Persians using Hail Caesar Rules.
Yep, my mistake. When I left on the last meeting it was all still being confirmed. I'll have to stay till lock up this time, then I'll know.
Quote from: skywalker on 08 September 2016, 11:28:24 AM
Joe (Zabadak) says that your game was his favourite on the day - shame there wasn't a public vote for best game.
Rimmer: "Aliens."
skywalker
Quote from: skywalker on 08 September 2016, 01:29:38 PM
Nice of him to say so. Please pass on my thanks :D :D :D :D
I will do.
Club Night #1 (26th August 2016)
Attendance: 6
Games: 1
* War of the Roses in 6mm (multiplayer, Hail Caesar)
Yorkists to the Left of the photos, Lancastrians to the Right
The Yorkist Left begins to advance forward
The Yorkist Centre and Right
The Lancastrians await their first turn
The Yorkist Left smashes into melee, while the Centre comes under volleys of arrow fire from their Lancastrian counter-parts
The Yorkist Left is beyond their enemy's front lines, and having succeeded in melee they're ready to attempt a turning of the Lancastrian army's flank
The Yorkist Right, secure in the knowledge that the Centre units will act to secure their flank, is about to push forward to meet their enemy in melee
Two shots of the (nearest to camera) end of the battlefield - Yorkists closest to camera
And they're in! Pushing back the extreme flank of the Lancastrian army, the Yorkists follow them up.
Elsewhere, now the Yorkist Left has control of their end of the battlefield, the Yorkist Centre surges forward and forces the Lancastrians standing against them to flee from the field - Leaving the way open to sack the Lancastrian baggage camp ... If only I'd not failed my command roll and had been able to move my troops!
The End. The Yorkists control the centre of the field. Only token Lancastrian resistance is to be had on the Yorkist's left flank. And now the Yorkist Right has encircled the last enemy units on their side of the battlefield, swiftly causing them to rout. Victory to the Yorkists.
##It needs to be said that my role of (successful) command of the Yorkist Centre was more down to good luck than great generalship. Getting those poor dice rolls out of the way early on always helps, when it came to melee my dice rolling was good.
Rimmer: "Aliens."
That looks proper.
Nothing like small scale figures to give you the sweep of battle.
How many stands were you using for a unit? I'm not quite sure if you have 6 stand units, or just happen to have all your troops in a division close to each other.
Hello Fred. I honestly haven't got a clue how the troops were sorted out.
On the night I had:
x1 commander
x1 Artillery base
Unit A: x6 bases of infantry formed together [retainer]
Unit B: x6 bases of infantry formed together [levy]
Whether these six bases could have been detached to form seperate units, I don't know. Nobody did so in the game, and I don't know the rules at all.
Bodvoc should be able to explain things, as he's playing Hail Caesar tonight at the club.
Rimmer: "Aliens."
Bodvoc
They are indeed 6 stand units with 24 figures per stand.
In tonight's game one stand of 30 hoplites/immortals etc..will be one unit. I only have several hundred figures painted whereas the chap doing the WOTR has about 4,000.
Quote from: Bodvoc on 09 September 2016, 01:51:55 PM
It's always cool when you have enogh figures painted to make big chunky units. If my maths is right you have close to 150 figures in a unit.
10 September 2016, 09:05:02 AM #70 Last Edit: 10 September 2016, 09:08:32 AM by RoyWilliamson
Second club night at The Old Guard Wargames Club and I took along my ACW naval.
My game's table quicky turned into a mess of QRS, dice and token, with me scrabbling to find the correct rule or chart needed to continue the game - But, it being a first game, this should be resolved in the future.
There's a bit of a game report over on the blog, here
LINK
for those interested, but the images are less photogenic, game detritus in shot, and the latter turns are only a write up as time was short and photos less of a priority.
Westmarcher, I believe it was yourself who asked me how I found the Smoke on the Water rules, in a comment earlier in the year.
Well, a part from the bouncing between roll on Chart A - now dice against Chart B - to roll off against Chart C, it wasn't too bad.
By the end of the game it was flowing more easily, we both knew the orders and movement mechanisms easily enough, shooting was still the need to check against the charts every time, the hardest bit was figuring out what happens in a collision - it happened twice, with the CSS Chicora pin-balling between two Union monitors. A minute or two reading the rules book to make sure I understood it and I'd worked it out.
The biggest downside I found to this first game was the scattering of paperwork everywhere, it being a real nuisance to keep together and find the correct sheet asap. But, by turn 10 we both knew how things worked and the majority of the rules we'd figured out and retained to memory.
I would say the game would work best with a player with a good working knowledge of the rules, and another who has a some familiarity of them. Then new players could be added. It really was hard work with one person running the game and trying to play at the same time.
Apologies if I've got the wrong forum member.
Starting positions: Union monitors to the left of the photo
The Confederates: Virginia following Chicora line-astern
from left: Weehawken, Monitor, Nahant
- There was two other games on the night, and I'll add what photos I can if the other players share the images they captured from the night.
Rimmer: "Aliens."
Stig
Hi chaps, its been ages since i posted on this forum..sorry....
The WOTR figs are mine, and originally done for Impetus on 60mm - 30mm bases. I just put 6 bases together (3 retinue bills and 3 Longbowmen) together to form mixed retinue units. It worked quite well I think. Hail Caesar is great for big multiplayer games like this.
Roy, and Bodvoc, cheers for sharing the pics of our little club!
Steve
Quote from: RoyWilliamson on 10 September 2016, 09:05:02 AM
Possibly was me, Roy (sorry, I cannot remember  :-[ - it's me age) because I was genuinely interested to read how you to on with them and what your thoughts were. I read them a long time ago after seeing them used by the SESWC in Edinburgh on Angus Konstam's website but have never played them. I seem to recall that they used 'wake' markers placed behind the vessels to denote speed - 1 for slow and 2 or 3 (in a line) for faster speeds. Thanks for your views. Attractive models and layout.  :-bd
Bodvoc
It was another fun night last night with 3 good looking games that seem to showcase a small, fledgling club well.
In keeping with my love of ugly military hardware, I've always liked ACW ironclads.
The CSS Virginia would be about 20" long and 4" wide in the one true scale.  :-\
That's do-able isn't it?
Quote from: Westmarcher on 10 September 2016, 10:57:41 AM
No worries. I'm sure it was yourself.
Yes, I remember the wake markers and did think about them during the game. One thing that is a definite, is you need maker tokens in this game. Keeping track on speed to figure out the shooting modifiers is the issue, also collision impact speed. I'd have been lost trying to keep tabs on the five vessels without the game markers, so they're definitely a necessity in my opinion.
Next biggest thing was remembering which guns had shot - Virginia was a sailing artillery battery, so I had to turn the ship's data sheet piece of paper to correspond with how the model was and with my finger against the required guns went down the broadsides - crossing off the gun that irreparable jammed. Working out which gun could then be trained on to the target, with the guide templates and the base's white dots, all added to the time spent on gunnery.
The monitors were far easier. "Those two can't shoot behind themselves. That one can't shoot ahead. They've all got two guns. Heavy and Super Heavy being the various types."
Another issue being back and forth with the paper data sheets to reference armour thickness on the various target locations.
Anyway, it gets easier as you go along and I'd certainly play it again - but not every week, as it would leave me pulling my hair out!  ~X(
Rimmer: "Aliens."
Here's some further photos, borrowed from James (who took the forum meet picture at York)
6mm Ancients (Bodvoc & Pete)
15mm WW2 - Flames of War [Yorkie and James]
In the background of that last photo you can see me (ginger hair, sweating my balls off next to the radiator - why did I sit next to it?!) and John
Rimmer: "Aliens."
Bodvoc
Really good pictures those, showing our games off very well. :)
Nice looking games, though the Ancients battlefield looks a little bare to me.
I do like the effect of massed ranks of 6mm figures.
Slightly puzzled by what appears to be a cavalryman leading a unit of cows and pack mules??
Also like the look of 6mm on large table.
Noticed a horse unit with two man crews? Pilot and weapons?
As to the afore mentioned supply unit? (pack animals and cattle), I think of stampedes being used as weapons - the ancient equivalent of drones?
There won't be a third time, late or otherwise.
