What type/make/size brush(es) do you use?
Started by getagrip, 10 February 2015, 10:09:47 PM
I've never thought about it before now, but I reckon that's the thing that I found as well.
I've some Foundry brushes that are long, and some Army Painter that are 3/4 the length of them and it's the AP brushes that I go with every time.
They both have the same point, but the longer length meant that the middles sort of billowed out on me (between the two points of contact/pressure at both ends where I'm holding the brush and the points in contact with the miniature).
Bodvoc
Just a quick note to say that the cheap brushes I got from the Works in Feb., the first one has just lost it's point so that is about 7 weeks of good usage for a 50p brush.
getagrip
Quote from: Bodvoc on 08 April 2015, 08:53:28 PM
I bought some because of the chat here and they're great for the brutal stuff: glue, drybrush etc.
Couldn't use them for "real" painting though.
The Sumerians I posted are painted with "Works" brushes.
getagrip
Quote from: Ithoriel on 09 April 2015, 09:21:59 PM
Wish I could use them like that ; would save me a bit. :)
kyussinchains
I used GW for years, recently switched to rosemary and co series 401 red sable blend brushes and I ruddy love them! I also picked up a W&N s7 and R&C's own pure kolinsky brushes and I find both too soft for my liking
I use a 1 for normal work on 6/10mm models and a 000 for fine detail, got some masters brush soap and they're going strong
I also use R&C hoghair brushes for drybrushing and they are great too, tough as old boots and get the job done!
my hobby/painting blog: full of 6mm goodness coming soon, 10mm goodness too!
Home of Epic: Armageddon on the web! It's still very much alive!
my tale of epic gamers 2013 log, contains lots of yellow marines :)
Ken
I use a Windsor/Newton series 7 #2 for everything, I would be so screwed without it.  :'(  Good thing I stocked up  8)
getagrip
Recently changed to WN, they are really good.
I use GW for general stuff and Works "smart price " for everything else.
Bodvoc
All of my recent figure painting has been done with brushes from the Works, as long as you clean them after painting they keep their point.
