What type/make/size brush(es) do you use?
Started by getagrip, 10 February 2015, 10:09:47 PM
getagrip
I currently use EE standard brushes for most of my painting; I like their size in hand, absorbancy and resistance.  they are pricey though and would like and alternative.  So, what's your favourite?
I use Italeri 000 for painting and a bigger brush I got from a craft shop for doing washes. I am quite hard on the brushes so use 2 or 3 every couple of months
Series 7 Windsor & Newton...(Series 16, if they still make those ?)..
WHEN I get the chance to use them.  ;)
getagrip
Quote from: Fenton on 10 February 2015, 10:14:35 PM
Wow!  Small, no wonder you go through them!
Quote from: Techno on 10 February 2015, 10:16:32 PM
What size Phil?
[Whilst waiting for Phil's answer]
This is good because (1) its a question I've been meaning to ask to see if I can improve my results on my 10mm figures and (2) I need new brushes (I'm wary of ordering online and tend to go to the art shop - hobby shop went out of business - to buy my brushes because I want to ensure I get a good point on the brush). Grip, when you say EE brushes could you clarify, please? Ta.
Subedai
I use The Works £1.99 for 4 0, 000, 00000, 0000000000) for detail work, Still on my first set and I brought them about the middle of last year.
http://www.theworks.co.uk/p/paint-brushes/nylon-round-brush-set---pack-of-4/5052089006089
For drybrushing I use any one of these, also from The Works. They are hard and scrape over the top surfaces very well.
http://www.theworks.co.uk/p/paint-brushes/boldmere-flat-brush-set---12-pack/5052089134607
For acrylic washes I use a slightly bigger brush. I have a specific brush for magic wash and another, separate brush that is only used for enamel varnishes. Another large artists very soft watercolour brush is only used to remove bits of fllock from figures. Sometimes I will buy a brush from the GW in town or at a show, depends on the state of my current lot.
I suppose if I could be ar*ed I would use W and N top of the range but to be honest even though there are a couple of art shops in town but I've never looked, those Works ones do it for me.
Blog is at
I have bought some from The Works some have been great but have  had a few bad ones from them
getagrip
I'm really shocked you guys use brushes from the Works.  I will give them a look.
West, EE (Evil Empire: Games Workshop) ;)
I got one from The Works turned it upside down and all the bristles fell out
getagrip
Quote from: Fenton on 10 February 2015, 11:10:29 PM
Yeah that's what I expected  ;D
SV52
W&N Series 7 S1,2,3.  I find a good point is the most important criteria, in my experience too small a brush doesn't hold enough paint and with some acrylics it's dry before you can apply it, unless you're quick.
Matt J
GW brushes as I use their paints and their brushes are the only ones I've found to work with them.
I have to go in the shop though to go through the best points and the standard has dipped last couple of years. Started using a new one tonight, nearly threw the f**king thing through the wall!
Beep
Hobbygames, Cotman, Citadel, Boldmere (The Works) and Pro Arte Prolene in use currently.
Assorted types in sizes 000, 00, 0, 1 and 2 plus some big flat brushes for basic colours on large things (like 20mm scale tanks) and a couple of make-up brushes for drybrushing things like tanks and buildings.
If I'm painting every day I'd expect to trash at least one brush of one size or another every month. At which point they are usually relegated to applying glue or similar chores.
Some GW ones I've had for years, Humbrol that I got via a Xmas present for our son and one other I can't remember the name of. Basically when I need a new one I just pop into out local model shop and look to see which ones are good and for a reasonable price.
Bodvoc
I use the better quality Humbrol brushes, some by Javis (pure sable) and a few by GW. I also buy from Art shops and will look at the Works brushes now too.
