Woodland Indians
Started by Minenfeld, 13 March 2010, 01:40:12 PM
Minenfeld
I know these are available in the SYW range, but will they be redone for the AWI range. I ask this because the AWI figures are  significantly larger than other Pendraken ranges. Regards.
I've cast off some of each and I'll get some pictures taken of them together.  The AWI are slightly bigger, but not by a large margin.
I've got them here - I wouldn't be worried about having these together...
Minenfeld
Thanks Leon and Nik for that, I'll use the SYW Indians then ! Great range and great painting btw Nik !
Thanks  8)
If you can bear with me for a bit [batteries on charge as I type] I'll take a quick comparison pic later...
Here you go - Woodland Indians [FI 13] & American Militia Firing Line [AWA5]
Cheers for that Nik, saves me a job!
Minenfeld
I see your point, I stand corrected. Thanks again .
