ITLSU 1914 Project
Started by pierre the shy, 25 June 2014, 10:01:11 AM
Wondered what on earth you were saying there for a moment, Michael.  ;)
Indeed - you can't have a nicely trimmed lawn in a desert battle.
Good progress last night, with Spring here and daylight saving started I varnished the last batch when I got home from work  :)
If the weather is as forecast I should get to take pictures tonight
Also dry brushed the horses and base coated the uniforms of the current batch :)
01 October 2014, 07:04:27 AM #263 Last Edit: 01 October 2014, 07:11:09 AM by paulr
The weather cooperated so..
Two German infantry battalions
Close up of infantry
Note the bayonet knot White, yellow, red - Third battalion, second company
11 on helmet cover and yellow epaulettes - 11th Regiment
German MG battery
Actually some spare infantry and dismounted dragoons wondering why their bases are labeled MG :-/
German Spotter
Photobucket has "lost" the British Spotter so here he is again
If he is Harry Spotter as FK suggests does that make the German Heinz Spotter :-\
Very nicely done indeed  8)
Very neat and tidy, as always. The dark flock really sets the German infantry off.
These look absolutely brilliant
Matt J
Lovely work Paul, how's your eyes after doing all those bayonet knots and epaulettes  @-)!
Beep
Quote from: Matt of Munslow on 01 October 2014, 01:33:46 PM
The eyes are holding up fine  :)
The tricky bit with the bayonet knots is I do them after I have based the figures so that I don't mix them up and the knots match the colours on the labels. A few of them have been 'interesting' to reach with another figure in the way.
It should really be only yellow piping on the epaulettes but that wouldn't have shown up and was probably going a bit far  ;)
I don't bother with bayonet knots.
kustenjaeger
Greetings
I may have missed this in the thread but what base sizes are you using?  I was basing Russians for GWSH but might well switch them for ITLSU.
Regards
Edward
kustenjaeger
I forgot to say, the painting on these is superb. I'd never even think of doing sword/bayonet knots :-).
Regards
Edward
Quote from: kustenjaeger on 02 October 2014, 10:04:48 AM
We are basing infantry on 25x25mm and cavalry, mounted and dismounted,  on 30x30mm.
In ITLSU each base is a platoon (section if guns or MGs) and the basic unit is a company so a step down from GWSH. There are a few reports of our games in the Batreps thread to give you a feel for how ITLSU plays. We are really enjoying using them for the open warfare in 1914 and are looking forward to using them for Sinai.
Quote from: kustenjaeger on 02 October 2014, 10:06:53 AM
Thanks, I decided to use the bayonet colour code for the colour codes I use on all my labels.  I then wondered if I could do the bayonet knot on a few figures... ;)
Tried and it turned out much easier than I expected  :D
Shecky
 :o :o
Simply wondermus. I'll have to check out the ITLSU batreps again. I've built early war forces for a Portable Wargame project but the stands can easily be used for ITLSU. I'll have to pass my initiative roll soon and post some pictures of the Portable Wargame in action.
kustenjaeger
Greetings
Quote from: paulr on 02 October 2014, 06:29:10 PM
I'd just make the point that ITLSU does not use 'platoon' bases - the unit is a company of a variable number of bases (see p6 where the author makes clear he has chosen the number of bases in recognition of likely strength). Remember that each two man base is about 40 men. So if you use a platoon per base you end up reducing the manpower strength of a German company with its 3 züge to 120 men (about 50% TO&E) as opposed to a British company with its four platoons at 160 men (66% TO&E).  Of course this may be what you want, depending on what actions you are depicting.
Regards
Edward
You are indeed correct, I should have used 'platoons' rather than platoons.  :-[ ;)
We typically use 3-4 bases per company as per the rules which is possibly a little low for France in August 1914 but about right by September  ;)
Finished painting the horses in the current batch  :)
Have also done saddle blankets and blanket rolls, just harness and bags to do  ;)
Well, apart from lances, carbines, uniform details and flesh  ;D
