Paint on the Final Base?
Started by lentulus, 09 July 2010, 01:23:28 PM
lentulus
Since the question has been asked, I am curious too.  Not that there is a right or wrong way, but preferences are interesting.
Aart Brouwer
Quote from: lentulus on 09 July 2010, 01:23:28 PM
Never! In all my, um, 0,8 years as a wargamer!  ;D
Really, I can't imagine getting all the details right if I have to move my brush in between several other models on a base.
Aart
goat major
paint on strips of wood stolen from Costa. gloss varnish on strips. Base and then matt varnish.
28mm individual figures i might do on final base (and 40k figures) but never 10mm or anything on a multi figure base
Sandinista
usually i base after painting, but my first unit of BUF (Richmond, N. Yorks) I did as 3 figs on a 20 x 30 base and painted on final base. I could not imagine doing this on a more densely packed base, say a pike block, but for these I was happy with results. I may get organised and stick a pic or 2 up soon.
OldenBUA
For infantry, attach to strips of cardboard, paint, then base and varnish. Not enough spacing on my bases (5 figs on 6x3 cm, for BKC) to paint on the final base. But I have done so for 15mm DBM psiloi, light horse and auxilia. Might do this again for some stuff (spotters, AT guns, scouts).
I have painted vehicles on the final base, but I now prefer to paint them first, then base them.
Aander lu bin óók lu.
Always base them & then paint: essentially:
Infantry / Cavalry : paint base first, then infantry
Modern AFVs / Artillery: paint vehicle first, then base [for muddiness]
Simples - and faster ;D
17-21l
I hate basing- so  get it over with at the start - as in basing and painting the base at the start- then I can 'look forward' to painting the figs, only my POV but at times I spend a whole evening basing then painting the bases- ust to get it done, - some people divnt like painting horses- I divnt like bases
>:( :D
God Save the Queen
Derk G
For 6mm and 10mm I paint on the final base. For everything else I glue the miniatures on my endless supply of old humbrol cans (I use Vallejo nowadays).
DanJ
Depends on the type of unit.
Light/skirmish units with few figures in open order I put on final bases then paint as there's room to get the brush all round.
Close order units get stuck on lenths of wood then painted then based.
The_Shootist
Base figures, undercoat, apply sand to base and do base coat for base. Paint figure then dry brush base and appply flocking.
SV52
Maenoferren
I have just painted all the bearers on strips then put them on the individul bases, however with the hunters and tigers they are based then will be painted, but as it is years since I did 10mm last I dont know which I will continue with
Both. Though not at the same time. For WWII I base then paint, the troops are in loose order so it is easier to get the brush around.
For ranked troops I paint blocks of troops on strips of hardboard or card board, stick the figures on temporarily with double sided sticky tape. For single based I do them on strips.
ba22er
Same here,
WWII base then paint Ainchients paint then base it is all a case of wether there is a big enough gap for me to get my brush in.
My vote applies to stuf which is going to be in closish order, so for instance with Modern, WwII, WWI infantry and guns I would base first. Also if its very small scale stuff I base first, such as 2mm/3mm
