19 January 2021, 01:57:43 AM
314452 Posts in 18208 Topics by 2277 Members
Latest Member: Chalace
| | |-+  From bag to base - Painting Pendraken 10mm ACW
Pages: 1 2 [3] Go Down Print
Author Topic: From bag to base - Painting Pendraken 10mm ACW  (Read 31517 times)
get2grips
Guest
« Reply #30 on: 10 January 2014, 05:50:16 PM »
Thanks Fenton Wink
You really use this?  Wax???  Can you paint on top of it?
« Reply #31 on: 10 January 2014, 05:52:23 PM »
I dont. I use it a replacement for Army painter..I use Vallejo quick shade black over grey to bring the details up ...I use the Klear stuff on larger 28mm models on 6 and 10mm I use W&N Nut Brown ink
« Reply #32 on: 10 January 2014, 05:53:05 PM »
I was down in Sainsburys about an hour ago and looked at the bottle and its the same stuff as I have
get2grips
Guest
« Reply #33 on: 10 January 2014, 05:53:56 PM »
I've used AP on 10mm skellies; would pledge do the same?
« Reply #34 on: 10 January 2014, 05:55:48 PM »
yeah should do but of course you make the mix to what ever strength you want or different colour..I use the Klear and Army Painter strong tone ink cos I'm a cheapskate
get2grips
Guest
« Reply #35 on: 15 January 2014, 07:37:07 PM »
Anyone using Army Painter dip should give this a go: works really well Thumbs up
Thanks again Steve Wink
Major General
« Reply #36 on: 10 March 2014, 04:26:00 PM »
I use B&Q's quick drying wood varnish in rosewood, about a fiver a tin and lasts for ages, gives good shading and cover. A good matt varnish across the top is needed though!
get2grips
Guest
« Reply #37 on: 10 March 2014, 06:43:03 PM »
I think Nik uses something similar Undecided
Major General
« Reply #38 on: 10 March 2014, 07:04:22 PM »
He might have inspiration, along with Tim of Madaxman fame! Works well, lasts ages, cheap as chips Smiley
Moderator
« Reply #39 on: 26 July 2014, 09:35:01 PM »
Yep - Wilko's Wood Stain. About 3 for a decent-sized tin...best diluted a bit.  Smiley
Itinerant Hobbyist
« Reply #40 on: 26 June 2018, 10:23:23 PM »
What size were those bases?
Tobbe
« Reply #41 on: 05 November 2018, 09:56:16 PM »
HCA-1 20 x 20mm
https://www.freewebs.com/pwsltd/steelbases.htm
« Last Edit: 05 November 2018, 10:00:22 PM by Tobbe » Logged
Im about to embark on the fools mission of setting up Battle of the Auroch Hills with 10mm figures as well as building a scale model of the battleground. Maybe next year.
« Reply #42 on: 19 May 2019, 01:55:55 PM »
A question:
I've used Pledge as a dip / wash at the end of painting, but never as an undercoat.
Does it's glossy finish cause problems with applying acrylics to the figure?
« Reply #43 on: 19 May 2019, 07:55:42 PM »
My experience is no when I have used as a wash over white primer.
Pages: 1 2 [3] Go Up Print
