my first 10mm AWI
Started by chalkie, 22 August 2013, 04:11:21 PM
chalkie
Tis is my first ever10mm paint job. Be gentle...lol
chalkie
Pics are a bit naff for sime reason.
chalkie
Iam not sure , these are a few I had spare, I've dry brushed the waistcoat and cross belts to get the black shading effect but still not to sure.
the paint looks quite thick by looking at the photos
kev1964
Hi Chalkie,
Coming on well, i havn't used washes before but it might be worth putting one on now, black or light brownish, but the guys who use them are the ones to ask.
I black under coat and leave a very thin black line between jacket, trousers , straps etc when putting the base coats on, it picks out the detail more, but it depends on how quick you want them on the table though as to the way you go about painting them. Look forward to seeing more,
kev
Coming along nicely Chalkie.
get2grips
Good start: agree with the wash suggestion, it helps calm a figure down and "tie" it together.
Don't know how long it is since you picked up a brush but you clearly have good control.
Nice job  :-bd
chalkie
I agree Fenton the paint does look a bit thick, it's the white cross belts and waist coat that is getting to me, just looks messy but if the dry brush way is meant to look like that then I will go for that. I will keep on at it.
chalkie
When dry brushing you want very little paint on the brush (this is the dry bit) but the paint probably wants to be quite thin.
Get some paint on the brush, then wipe most of it off on a tissue. To check if you have the right amount of paint on the brush, I often do a practice swipe on something, a painting stick, or the wooden base of the figures can be useful for this. If this gives a light coat of paint then you are probably OK. Then do a light swipe over the figure.
Aim to do two or three light swipes rather than 1 heavy one.
get2grips
Personally, and especially on 10mm minis, I hate drybrushing except at the very start of the process.  I never use it to finish.
get2grips
Quote from: get2grips on 22 August 2013, 06:24:09 PM
I would agree with this...better a good quality 000 brush and just paint the cross belts in
The only thing I drybrush now iis chain or plate armour
chalkie
So would you say that these figures arent that good then ?
