24 November 2020, 10:05:29 AM
310617 Posts in 18051 Topics by 2269 Members
Latest Member: BKC Grenadier
| | |-+  Cleaning the minis
Author Topic: Cleaning the minis  (Read 1776 times)
count_zero99uk
« on: 03 June 2010, 12:24:47 AM »
Ive normaly dealt with 28mm or 20mm minis, do you bother cleaning with file and knife, and if any tips so you dont rub someones face off.
Brian.
lentulus
« Reply #1 on: 03 June 2010, 12:53:10 AM »
I do  a bit of cleaning, but little is needed - save the bases, which almost always need a quick pass with a file.  I have never had a problem with loss of detail - serious problems are very rare with Pendraken product.   I presume you use a very small file and by hand?
count_zero99uk
« Reply #2 on: 04 June 2010, 05:25:55 AM »
Yeah, i think i was jumping the gun somewhat with this post, the skeletons ive almost finished (FU1) needed none.  So maybe im just used to needing to file of flash on the 28mm's.
Ill post some pics of these when ive finished them later today.
Personaly i think they look great, my first 10mm
Moderator
« Reply #3 on: 04 June 2010, 11:34:51 PM »
Agree - you'll find little in the way of flash on Pendraken...although you'll get mould lines from time-to-time: trick is that you'll get more consistency than you're used to - so if you spot something on the first figure, you'll likely need to take it off all of them - although, with 10mm, it's *way* less noticeable of course: main features to look for I'd suggest: lines on headgear [top of head is prominent on 10mm on-table] & back of trailing leg [ditto]...
It must be said though, that the vast majority of the time you can prep PD figures with two swift passes of the knife: first to the base, second usually to mould-line on head/hat/helmet
count_zero99uk
« Reply #4 on: 08 June 2010, 07:52:49 AM »
here are the pics
http://www.pendrakenforum.co.uk/index.php?topic=743.0
