ACW Union Blue Coats
Started by Bunny, 15 March 2013, 10:19:30 AM
Bunny
Hi Guys,
I would thought I would ask the group what would be the best 'blue' spray colour to use to do Union jackets.
Bunny
Spray ?
Royal Blue looks about rigth in 6mm so should do you.
Sean Clark
Army Painter do an Ultramarine blue which I use. So long as you follow the instructions on the can youll be fine.
God's Own Scale podcast
If you're going to highlight after spraying I'd recommend a darker blue, like navy. Highlighting always makes the colours look lighter.
Sean Clark
My method is spray with mid blue, wash with dark brown or black, then highlight back up.
daveyboy21
I use a mixture of blues for Union jackets to represent the rigours of campaign. Just ensure that the blue is not too light
"When you have nothing to loose...........THEN you have Everything to fight for"
I find Vallejo Oxford Blue is a good darkish blue. For campaign-worn jackets I have stumbled across Daler Rowney acrylic Prussian blue in a tube. You only need a little as it is quite thick. Thinned with water and painted over a white undercoat it gives a good faded veterans coat.
