SYW Austrians & Prussians
Started by nikharwood, 01 June 2010, 09:17:38 PM
01 June 2010, 09:17:38 PM Last Edit: 01 June 2010, 11:24:13 PM by nikharwood
Right - I've decided that I will do my SYW Austrian & Prussian armies as fast-paint - mainly because:
- it's summer
- I'm playing & coaching a load of cricket (again)
- work is manic
- cider / lager / wine is nicerer in summer  :P
Fast-paint means I will get them done & on table in decent time - rather than obsessing over these until my eyes bleed  ;D
It also means I'll cut some corners, but still try to make them look lovely  8)
Right - here's the force composition:
Austrians:
General & commanders
1 x Light Infantry - Grenzer
6 x Infantry
2 x Grenadier Infantry
1 x Light Cavalry - Hussars
1 x Cavalry - Dragoons
2 x Cavalry - Cuirassiers
3 x Medium Guns
Prussians:
6 x Infantry
1 x Grenadier Infantry
2 x Cavalry - Dragoons
4 x Medium Guns
They're all based on 50 x 25 MDF bases, 3 bases per unit (inf/cav): 8 figures / base for Grenzer, 10 / base for infantry & 4 / base for cavalry. Here they are in prepped & based state:
Austrians:
Prussians:
Ready for spraying:
Sprayed [with final pass to come]:
Elapsed time to this point from unpacking them from bags: 3 hours
All have now had bases painted & overbrushing done:
Stage One: Bestial Brown - everything including figures:
Stage Two: Leather Brown - bases only:
Stage Three: Bleached Bone - bases only:
Only difference is that Austrian infantry is overbrushed with Grey rather than Brown at this point...
Elapsed time to here: 4.5 hours
kustenjaeger
Greetings
Nik - what do you undercoat with?
I'll be prepping my SYW Allied starter force over the weekend and am tempted to try your methods in part after my first test battalion was less than totally successful.  I probably won't base them first as mine will be on smaller bases and more tightly ranked and filed (6 infantry on a 25x20 base and 3 cavalry on a 25 x 25 base, guns tbd) so I'd have difficulty getting a brush in between.
Regards
Edward
These are spray undercoated using Army Painter Matt Black Primer
I have spaced these quite widely - I'd have no hesitation in employing the same technique on yours though - it's what I did with my ECW / Napoleonics & ACW [where I've got 14 figures in two ranks onto 40x20 bases] - no problem re painting as you paint what you can get to with your brush - the overbrush & lighting takes care of the rest....
Have a look here & see if you can see where I've not painted  ;) ;D
http://nikharwood.pbworks.com/ACWarmaster+-+Union+lines
http://nikharwood.pbworks.com/ACWarmaster+-+Confederate+lines
http://nikharwood.pbworks.com/Union+ACWarmaster+army
http://nikharwood.pbworks.com/WIP+Confederate+ACWarmaster
Where does the time go, eh?!?!!
Having mucked about with far too much research etc etc on trying to find uniform detail sources etc I've decided that I'll go with simplicity for my source:
http://www.juniorgeneral.org/load.php?Period=4#Seven
Great resource & will give me more than enough detail / accuracy for what I want to achieve with my SYW armies. I'm hoping (cricket & imminent World Cup shenanigans permitting) to start making a serious dent in the Austrians in the next few days...watch this space!
Grenadier
That's quite a project there Nik!  Good luck, I've never painted more than one regiment at a time, but having no one to game against gives me plenty of paint time! Hoping my Malburians come soon so I can try my first mass painting of 10's.
The Grenadier
To be honest, I always paint like this...I'm a 95% solo-gamer so inevitably end up getting both sides of any conflict...I also can't bear to go back to any army & add to it - would much rather decide at the planning stage the largest force I want to do & go with that - and once it's done, it's done  8)
Work is manic at the moment so I've stalled a bit on this one [& have picked up a couple of commissions too which is coolio] - so I'll get to this when I can...have done most of the planning though so I'll post more detail on my chosen colour-schemes soon...
jchaos79
Hi Nik, I do not really understand how do you overbrush... could you explain like you are explaining to a 11 years old children (or for dummies as you prefere  :-[ )
And what is the advantage of overbrush?
Is overbrushing the same as dry brush? (if the answer of this question is YES forget the other questions)
thanks in advance
No worries...here you go:
Drybrushing: take your brush, load with paint & then wipe off until it is *dry* and you're getting the faintest of colour-application on the raised-edge highlights...
Overbrushing / wetbrushing: take your brush, load with paint & then wipe off about half - then when you brush that across the figure you're hitting all raised surfaces...
So if you think about trousers:
- drybrush - you'll hit the top of the creases
- overbrush - you'll hit the raised cloth areas
Does that make sense? Let me know if not & I'll do some painted pic examples...
republic of tolworth
Hey Nick!
Thanks forth info on juniorgeneral.
It's given me loads of insiration for my 'fantasy' syw armies. Hurrah for the Grand Duchy of Fenwick!
jchaos79
Quote from: nikharwood on 12 June 2010, 12:02:20 AM
Thanks very much, it make sense.
your doing a good good job around here with a lot of very nice armies,
looking forward to see the SYW finished
12 June 2010, 01:58:15 PM #10 Last Edit: 21 June 2010, 09:38:31 AM by nikharwood
Right - here's my planning painting notes...these are base colours - basetones will be darker & most will be lightened with Bleached Bone / White for highlights. Apologies in advance if I get the 'technical' names wrong  ;)
All flesh: Dark Fleshtone highlighted with Dwarf Flesh
Austrian
Musketeers:
Uniform: White
Tunic: Ultramarine Blue
Cuffs / Facings: Regal Blue
Collar: Blood Red
Tricorne: Black / White piping
Cartridge Pouch: Grey
Gaiters: Black
Grenadiers:
Tunic & Trousers & Cuffs: Blood Red
Mitre: Grey / Red
Grenzer:
Tunic: Regal Blue
Crossbelt: Leather Brown
Cuirassiers:
Trousers, Turnbacks  & Saddlecloth: Regal Blue
Dragoons:
Coat & Saddlecloth: Blood Red
Trousers & Facings: Light Blue
Hussars:
Uniform & Saddlecloth: Sky Blue
Detail: Red
Hat: Earth
Artillery:
Uniform: Leather Brown
Cuffs: Red
Officer: White trousers
12 June 2010, 02:03:25 PM #11 Last Edit: 21 June 2010, 09:39:18 AM by nikharwood
Prussian
Musketeers:
Tunic & Trousers & Crossbelt: White
Coat: Regal Blue
Cuffs / Facings & Collar: Blood Red
Gaiters: Black
Grenadiers:
Coat: Regal Blue
Mitre: Grey / Red
Cuirassiers:
Uniform: Buff
Collar, Cuffs & Saddlecloth: Ultramarine Blue
Dragoons:
Trousers & Tunic: Buff
Everything else: as Musketeers
Hussars:
Trousers: Buff
Tunic: Blood Red
Hat: Black / Blood Red piping
Saddlecloth: Scab Red
Artillery:
Trousers & Tunic: Ultramarine Blue
Coat: Regal Blue
Tricorne: Yellow piping
Officer: White crossbelt
Gunners: Buff crossbelt
Gun furniture: Ultramarine Blue
12 June 2010, 06:31:21 PM #12 Last Edit: 12 June 2010, 06:33:38 PM by nikharwood
Quick pics: Austrian test stand: Musketeers (20 mins)
Very impressive for 20 minutes work mate 8).
kustenjaeger
Greetings
Nik - what do you use for groundwork on your bases?
Also which order do you paint different parts of the figure?
Regards
Edward
